Fixing stiction - Page 21 - Ford Powerstroke Diesel Forum
 45Likes
post #201 of 219 Old 07-12-2017, 04:02 PM
Quoted: 789 Post(s)
Originally Posted by Heavy_GD View Post
Who reads stickies?
We can barely get people to search.
I do, I remember I got chastised back when i joined this forum about reviving an ld thread after searching. the Audi/ VW forum i came from would flame you if u stated a new thread w/o searching for an existing thead that answered your questions
That said... stickies and the search function is my best friend... aside from posting.
2007 F250 Lariat Outlaw
174k
Stock Motor
5" MBRP Catback
Boudah is offline
post #202 of 219 Old 07-12-2017, 04:03 PM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
You two win the day.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #203 of 219 Old 08-21-2017, 10:02 AM
Quoted: 11 Post(s)
Originally Posted by litterbug View Post
Might I add when taking off the head or spool valve of the injector that it goes on in the same orientation as well. It will fit on the injector backwards. Then the spool valve goes in backwards and it will leak oil out the top two holes in the head of the injector. Just an fyi for anybody doing this. If this happens the truck will not start due to low icp. I found this out a couple nights ago while I was looking for a hpo leak after sanding my spool valves.
Is this no start a fact?
crankn101 is offline
post #204 of 219 Old 03-06-2018, 03:13 PM
iqraceworks's Avatar
Quoted: 162 Post(s)
Just bumping an old thread. For those of you who have had injector stiction issues....and went ahead and sanded/cleaned the spool valves.....how long did the fix last?
I'm going to have my heads off soon....and since the injectors will be out, I'm thinking about cleaning the spool valves in all of them. My truck runs pretty rough until the oil temp gets up over 90deg or so. I figured that as long as there are no negative side affects...I might try cleaning all the spool valves.......is it worth the trouble?
iqraceworks is offline
post #205 of 219 Old 03-06-2018, 05:10 PM
backhoebill's Avatar
Quoted: 1248 Post(s)
Send a message via Yahoo to backhoebill
I havenít cleaned my spool valves, but it has to be better than spending $1,600 on new oem reman injectors. I would definitely do it if I couldnít pony up the cash for injectors.
Sent from my iPhone using Tapatalk
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #206 of 219 Old 03-06-2018, 05:26 PM
Flamed99's Avatar
Quoted: 815 Post(s)
I have about 50k on mine since doing this and they still perform as well as the day I did it. Factory injectors at around 105k and now just over 150k. Truck starts right up at any temp and runs great. Even on single digit temps. I haven't even bothered plugging it in this year. Just run on high idle for a few mins then roll out. Prior to doing this the truck couldn't move out of its own way till it was warm. If you needed to go anywhere quick you had to have it plugged in, even in 80+ degree temps. Truck would just rev to about 2k then start to miss and pop. You would have to barely touch the throttle to get it to shift and do more than 20mph. If you already are pulling them for other work there is no reason not to do it. Once you do it and keep good oil change intervals and quality I doubt it would need done again. I can also say hotshots and revx won't do chit to help with stiction. I tried it for 2 oik changes before pulling the injectors for cleaning and it didn't change anything. I also tried running it in my other truck for a year to see if it would work long term and still no change. That truck isn't too bad that I have just dealt with it till I tear into if for something else.
Sent from my phone
backhoebill and Boudah like this.
'04 F250 CCSB XLT 2WD, lowered with a DJM drop kit. 305/40/22" Toyo ST2's on 22" x 10" XD 825 wheels. FloPro turbo back 4" exhaust with muffler delete, egr delete, bypass coolant filter, S&B intake, NUC bypass oil filter.
'03 F250 CCSB Lariat 4WD, 9" lift, 40"x 15.5"x 24" Toyo M/T's on 24" x 14" Hostile Hammered wheels, 4" exhaust, egr delete.
Flamed99 is offline
The Following User Says Thank You to Flamed99 For This Useful Post:
backhoebill (03-06-2018)
post #207 of 219 Old 03-07-2018, 03:46 AM
Quoted: 162 Post(s)
Sent from my phone
Good to know....thanks!! I guess since I'm going to have the injectors out anyways, I might as well give it a try. My truck run OK cold, just stumbles a bucks a little bit until the oil temps get up over 90....so I'm sure there is some stiction going on. Sounds like a really easy job....nothing compared to doing the heads cab-on like I'm getting ready to do. I guess when I get tired of laying on the motor and turning wrenches, I can work on cleaning the injector spools
post #208 of 219 Old 03-07-2018, 05:44 AM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
Is it tho??
The new gen2 injectors we have now are much better than what we had 3+ yrs ago when polishing was the thing to do. Considering the labor is LESS to remove and replace than to remove and disassemble and polish (if we are being logical and actually accounting for time spent which I know there will be a key board warrior that will hit me for "it only takes 5 mins per injector to polish" blah blah blah) the injectors, I think I would lean towards replacing with the new injectors with slotted end caps and all the updates.
I fully understand (frugal tidepod eaters) that you WILL save money polishing your OE turds....sorry injectors, but when weighing the pros and cons NOW, there is a ton more pros with the new injectors that there weren't available 3yrs ago. It is amazing how smooth and quiet these 6.0's run with a new set of gen2 injectors in them. It will make you love the truck again.
bismic and backhoebill like this.
toren302 is offline
post #209 of 219 Old 03-07-2018, 05:50 AM
Originally Posted by toren302 View Post
Is it tho??
I 100% agree, and that is why I have new injectors. I was thinking about folks that are tapped out for money. It is a good alternative if you have more time than money.
post #210 of 219 Old 03-07-2018, 05:56 AM
Bump To Pass!!
toren302's Avatar
But isn't time money??
I know I know. It is a good option for people that want to experiment and get more time out of a something. I just wanted to throw out that the new ones are much better than what we had years ago.
toren302 is offline
