Started ARB 140 install , some questions + pictures - Page 3 - Ford Powerstroke Diesel Forum
post #21 of 32 Old 01-07-2013, 07:12 PM
Quoted: 59 Post(s)
Originally Posted by smokersteve View Post
I did for that picture
On the pinion ware. The orriginal shim was .028. It had pressuremarks so I used new shims. I made a shim pack that was .026 - .027.
Is this ok????
I thought so! Hope your wife doesnt see this thread
Anyway, I think you're close enough on the pinion shim pack. You'll know for sure when you get the pinon set and the carrier reinstalled, and then check the backlash and contact pattern.
The wear on the pinion looks fine - especially for ~100K miles.
Keep up the good work!
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #22 of 32 Old 01-07-2013, 08:30 PM
Wildstang's Avatar
Going down .002 on the pinion shim will shift your pattern a little. You will see when you check it. It will probably still be acceptable, but you'll have to be the judge of that.
2003 Excursion Limited 6.0L - Ford 30mm sway bar(should be on these things from the factory!) zoodad, BTM, few deletes, upgraded FPR spring, 58v FICM, REV X!, 340k and counting...
1986 Mustang GT - Turbo SBF 9.60's @ 148mph
Wildstang is offline
post #23 of 32 Old 01-07-2013, 10:24 PM Thread Starter
smokersteve's Avatar
Quoted: 21 Post(s)
looking at it now, wouldnt it be the other way arround?? add .002?
The top of the pinion looks like it is getting more ware than the bottom.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #24 of 32 Old 01-07-2013, 10:25 PM Thread Starter
Quoted: 21 Post(s)
I think im going to take the bearing off and redo the shim pack. I can make a .030. And if im looking at things correctly the pinion would like that.... ?
FICM Testing Videos
post #25 of 32 Old 01-07-2013, 11:15 PM
snafu!'s Avatar
Quoted: 2 Post(s)
I have always been told when reusing ring and pinion, you want to keep everything the same. The gears have "worn in" and if there is a change there will be excess wear.
Good write up, thank you, it takes a lot of time to stop and take pictures.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #26 of 32 Old 01-08-2013, 07:52 AM Thread Starter
Quoted: 21 Post(s)
Well shoot. On another forum I have a tech telling me to re-use the shim. I will take a pictrue and post it on both and see what you guys say....
FICM Testing Videos
post #27 of 32 Old 01-08-2013, 08:44 AM Thread Starter
Quoted: 21 Post(s)
Here is my old shim.
I can feel the gooves with my finger nail.
FICM Testing Videos
post #28 of 32 Old 01-08-2013, 08:58 AM
rdaffin's Avatar
The original shim is fine. I would re-use it IMO.
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #29 of 32 Old 01-08-2013, 03:09 PM Thread Starter
Quoted: 21 Post(s)
I pulled the new bearing off of the pinion. I heated it up to 230*F and it came off.
So, all new bearings, crush washer, seas, and re-using pinion and ring gear.
The old shim is .028".
I can make a new shim pack of .0265" and a .030".
Should I put the old pinion shim back in? look at the picture of the old shim.
FICM Testing Videos
post #30 of 32 Old 01-08-2013, 06:45 PM
Quoted: 59 Post(s)
If your concerned about it, I would re-use the old shim. That way the mesh will be the exact same. I see no problem re-using shims. It's not like your trying to re-use oil seals or crush sleeves.
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
