Started ARB 140 install , some questions + pictures - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 32 Old 01-06-2013, 10:59 AM
any updates?
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #12 of 32 Old 01-06-2013, 05:15 PM Thread Starter
smokersteve's Avatar
Quoted: 21 Post(s)
yea I will post pictures tonight or tomorrow morning.
I have the ring and speedo gear on the arb, both bearrings, shims, and air ring on the arb, and pinion out but bearrings have not been pulled yet.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #13 of 32 Old 01-06-2013, 05:41 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 21 Post(s)
I can't find a Ford number but I found what you're looking for.
QU20004 Axle Shaft to Hub Sealing Ring for Ford Sterling 10.25', 10.50" Rear Axles
dhanna6powerstroke is offline
post #14 of 32 Old 01-07-2013, 11:40 AM Thread Starter
Quoted: 21 Post(s)
Thank you for finding that. If I dont get an OEM part number I will get that.
I loaded more pictures.
I would greatly appreciate advice on installing the pinoin.
FICM Testing Videos
post #15 of 32 Old 01-07-2013, 12:34 PM Thread Starter
Quoted: 21 Post(s)
How does my ware look?
FICM Testing Videos
post #16 of 32 Old 01-07-2013, 12:57 PM
Joeshu1000's Avatar
Quoted: 6 Post(s)
Subscribed.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Rudy's Cold Air Intake
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #17 of 32 Old 01-07-2013, 01:01 PM
sweet write up. Thank you for taking the time to do it
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #18 of 32 Old 01-07-2013, 05:17 PM
Quoted: 59 Post(s)
Steve - You dont have the pinion gear on the kitchen counter do you?
BTW, great job so far. Thanks for posting!
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #19 of 32 Old 01-07-2013, 05:34 PM Thread Starter
Quoted: 21 Post(s)
I did for that picture
On the pinion ware. The orriginal shim was .028. It had pressuremarks so I used new shims. I made a shim pack that was .026 - .027.
Is this ok????
FICM Testing Videos
post #20 of 32 Old 01-07-2013, 06:02 PM
kcoyner's Avatar
Quoted: 217 Post(s)
THANKS for putting this thread together with the great pics!
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
