Pod/Gauge??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-17-2012, 05:14 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
Pod/Gauge???
Getting ready to get a 4 pillar pod and gauges. Already have a Boost and EGT gauge, nothing else. Which things do you recommend i should monitor. was thinking of Fuel pressure, Coolant Temp, Oil Temp, Volt. what ya think?
asian195 is offline
post #2 of 8 Old 01-17-2012, 06:08 PM
War is the answer!
WarChild's Avatar
Quoted: 29 Post(s)
I would have gotten an Edge CTS and usually you need to watch ECT, EOT, ET, TransT, Bat Volts, FICM Volts. The first 3 being the major ones and the 4th if you tow is a must. Never trust your dash guages by the time they tell you something is wrong then its already ****ed up. Good monitoring can prevent damage thats why an Edge CTS is so good becouse iyou set levels and when they exceed those levels you know something is going wrond befor it breaks.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 8 Old 01-17-2012, 06:22 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
I plan on a cts when I can afford one. But, it doesn't do fuel pressure without their eas stuff. Plus I like the look of pillar pods.
My boost and egt are on my attitude monitor.
Sent from my PC36100 using AutoGuide.Com Free
asian195 is offline
post #4 of 8 Old 01-17-2012, 06:48 PM
Glow Plugs Only
dee004's Avatar
I have Trinity T1000 which monitors most of the sensors as well as EOT, COT, TT, EGT, Volts, Boost and fuel pressure gauges.
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #5 of 8 Old 01-17-2012, 08:13 PM
u should just get a scangauge2 and monitor fuel pressure, low side oil pressure as the truck doesnt have a real gauge and whatever else. if u didnt have the attitude monitor, the sg2 and bst, pyro, fp, and low oil pressure would work great in the pillar.
joe_r_dog is offline
post #6 of 8 Old 01-18-2012, 04:42 AM
SVO Ryan's Avatar
I used to love pillar pods as well, but realized how much of your vision they block. If you really want gauges, I'd go with the above the mirror mounted pod.
SVO Ryan is offline
post #7 of 8 Old 01-18-2012, 05:16 AM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
My attitude is above mirror. I know they block vision. But not too worried about that.
asian195 is offline
post #8 of 8 Old 01-18-2012, 12:39 PM
goosegodz's Avatar
My gauges are egt, fuel pressure and oil pressure. Air pressure is next for the onboard air compressor n train horns coming soon. I monitor everything else with my CTS.....
goosegodz is offline
