Billet Fuel Filter Cap - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 37 Old 01-16-2012, 06:03 PM Thread Starter
ctrow89's Avatar
I went ahead and ordered me one of the billet secondary fuel filter caps and put it on, but it leaked. I ordered mine off of flea bay which very well could be the problem. Where did you all order yours from and do they leak? Mine was leaking from the threads...
ctrow89 is offline
post #2 of 37 Old 01-16-2012, 06:26 PM
Face Down's Avatar
Did you remember the o-ring? Would you mine posting which one from eBay you got? I ordered one also and it is sitting on my shelf waiting to be put in.
2006
F350 FX4 CC LB Dually Lariat Loaded
BIG SEXY
Edge CTS Insight w/ EGT & BU Camera
SCT X3 w/ Tunes from Quick Tricks
LT255/80R17 Cooper Discoverer S/T MAXX Tires
Rancho RS7000MT Shocks
PHP Atlas 40 Tuned FICM by FICM Repair.com
aFe 4" SS Turbo Back Exhaust
EGR & CAT Deleted & Sinister Coolant Filter Kit
Face Down is offline
post #3 of 37 Old 01-16-2012, 06:42 PM
asian195's Avatar
Quoted: 2 Post(s)
I got a Oil filter cap of of Ebay, no problems. Cant tell you which one, long time ago.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 37 Old 01-17-2012, 05:47 AM Thread Starter
ctrow89's Avatar
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
That's the one I got. It came with the O-ring already around it so there was no forgetting it. The guy said to wrap the threads a few times with teflon tape, but I wasn't sure if that was a good idea. Seems like it would be a PITA to have to wrap it everytime I changed the filter. Seems like one of them out there wouldn't require that...
ctrow89 is offline
post #5 of 37 Old 01-17-2012, 05:50 AM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
My fuel and oil filter caps are from Bullet Proof Diesel and they do not leak one bit.
john galt likes this.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 37 Old 01-17-2012, 05:53 AM Thread Starter
ctrow89's Avatar
Did you have to wrap your threads with teflon tape? Diesel Manor also has one, but not sure if it leaks or not?...
ctrow89 is offline
post #7 of 37 Old 01-17-2012, 05:57 AM
Quoted: 12 Post(s)
NO teflon tape on the threads!! The o-ring at the top of the cap is the sealing device. If it leaks thru the threads the cap was not designed correctly. There are some very important details that could be missed very easily.
Go with a known quality manufacturer!
a2elvis is offline
post #8 of 37 Old 01-17-2012, 06:01 AM
AMERICA!
I used teflon on the threaded plugs on top of the caps.
With that being said, should I take the teflon off of the plugs on top of the caps?
post #9 of 37 Old 01-17-2012, 06:07 AM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 22 Post(s)
Feedback Score: 3 reviews
You'll be fine with the Teflon used in the NPT plug.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 37 Old 01-17-2012, 06:08 AM Thread Starter
ctrow89's Avatar
That was my thought. I did do what rattlesnake did though and put it on the plug on the top of the cap.. is that a bad idea? I will for sure go with a reputable seller this time.. Guess trying to save a few $$ ended up costing me as usual..
ctrow89 is offline
