Billet Fuel Filter Cap - Page 4 - Ford Powerstroke Diesel Forum
 2Likes
post #31 of 37 Old 01-17-2012, 04:26 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
Originally Posted by Face Down View Post
Not to high jack here but I noticed that you hooked up your coolant filter the same way I did, only to be told that I did it wrong and the "T" back by the firewall is supposed to go in front of the heater control valve. I just swapped the two locations, now my heater control valve is where the "T" is and vise-versa.
Ahhhhh.... I was wondering about that when I installed it. Thanks for pointing that out.
Hijack over......
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #32 of 37 Old 01-17-2012, 07:20 PM Thread Starter
ctrow89's Avatar
Hijack over......
No problem on that because I just put mine on and had a hard time deciding which way to go. Luckily it only fit the one way after I grabbed 2" of heater core line from auto zone .. wouldn't stretch back by the firewall luckily I guess
ctrow89 is offline
post #33 of 37 Old 01-17-2012, 08:13 PM
squirtgun's Avatar
Looks like I need to swap them around on the 2 truck I installed them on. We haven't had any problems the way they are,but would rather have them in the proper way
2003 6.0L F250 4x4 Lariat
Fog Light Mod,High Idle Mod,Zoodad,Hose clamp taligate mod,08 rear bumper,Sinister EGR delete,ELC EC-1 coolant,Edge Juice,MKM(Sinister)coolant filter,HFCM drain plug upgrade,diy FICM repair(steady 48.5v now),DIY CCV mod,Torque Pro,Blue spring upgrade,Aluminum radiator,05 headlights,LED foglightd
Wish List/Things to do
Y-pipe,fuel pressure gauge,diy oil bypass(maybe centrifuge),oil pressure gauge
squirtgun is offline
post #34 of 37 Old 01-17-2012, 08:36 PM
Face Down's Avatar
From what I understand, behind the heater control valve the system is not always open so you are not always getting flow. What I do not understand if that it is when the heater is off, or when the AC is cranked on high. Either way, with the "T" in front of the valve you will always have flow regardless what your heating/cooling system is doing. Like I said I had it wrong first, I just then switched the position on the "T" and the heater control valve.
2006
F350 FX4 CC LB Dually Lariat Loaded
BIG SEXY
Edge CTS Insight w/ EGT & BU Camera
SCT X3 w/ Tunes from Quick Tricks
LT255/80R17 Cooper Discoverer S/T MAXX Tires
Rancho RS7000MT Shocks
PHP Atlas 40 Tuned FICM by FICM Repair.com
aFe 4" SS Turbo Back Exhaust
EGR & CAT Deleted & Sinister Coolant Filter Kit
Face Down is offline
post #35 of 37 Old 01-18-2012, 12:47 PM
Face Down's Avatar
I am putting mine on tomorrow and will let you know how mine turns out.
Just got mine on, no issues unless you count getting the plastic OEM cap off. Looks good and no leaks!
2006
BIG SEXY
post #36 of 37 Old 01-18-2012, 12:52 PM Thread Starter
ctrow89's Avatar
Were you able to use a socket for this? I tried on mine, but it wouldn't work. I would rather the socket not fit than it leak, but wish I could use a socket none the less.
ctrow89 is offline
post #37 of 37 Old 01-18-2012, 01:52 PM
Face Down's Avatar
Used a 24mm and Torque it to 14Nm.
2006
BIG SEXY
