manual fan control - Page 41 - Ford Powerstroke Diesel Forum
 73Likes
post #401 of 450 Old 05-09-2016, 07:41 PM
Quoted: 59 Post(s)
Originally Posted by Heavy_GD View Post
@Chatham036 ....
I am currently running Jay's tunes.
Chatham036 and Heavy_GD like this.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #402 of 450 Old 05-09-2016, 07:44 PM
Heavy_GD's Avatar
Quoted: 3147 Post(s)
Garage
Feedback Score: 4 reviews
His tunes kick the fan in nicely
Chatham036 likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #403 of 450 Old 05-09-2016, 07:56 PM
Quoted: 16 Post(s)
I have been running the SRL from Matt at
Powerstroke Diesel Performance Tuning
www . gearheadautomotiveperformance . com
He also does some nice tow stuff IMHO.
If you already have the device that can upload that will save you some $
Talk to them and tell them what you want to do and what device you have
and the strategy. They should be able to get you going quickly.
The programming device should be able to pull up your strategy
Sean
Yahiko is offline
post #404 of 450 Old 05-10-2016, 09:57 AM
Quoted: 176 Post(s)
As mentioned above, we can manipulate the point in which the fan kicks on based off your engine coolant temp.
If you feel we can be of assistance, I am happy to answer any questions you may have. If you feel you are ready to place your order, please visit Index of /
Chatham036 is offline
post #405 of 450 Old 05-11-2016, 01:22 PM
joeshmoe's Avatar
Quoted: 13 Post(s)
Originally Posted by STL06f250 View Post
Ok..I need to do the fan mod...questions first..
Is there a full write up with pics (for dummy's like me) on how to do the mod??
Here's the diagram you asked about:
FanGroundingRelay.jpg Photo by Abboom | Photobucket
05 F350 4X4 FX4 SC/LB
joeshmoe is offline
post #406 of 450 Old 05-11-2016, 04:54 PM
Quoted: 17 Post(s)
I don't have switches in my truck..
STL06f250 is offline
post #407 of 450 Old 05-11-2016, 05:01 PM
Master_Chase's Avatar
Quoted: 520 Post(s)
Then add some
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #408 of 450 Old 05-11-2016, 06:00 PM
Quoted: 17 Post(s)
I don't have the factory up fitter switches like his diagram has...
post #409 of 450 Old 05-11-2016, 07:55 PM
Quoted: 520 Post(s)
Then go to auto zone or somewhere are wire some in I have 3 one for high idle, one for an inverter, and one thats most likely going to be used for this since my clutch is dieing.
joeshmoe likes this.
post #410 of 450 Old 05-11-2016, 09:14 PM
joeshmoe's Avatar
Quoted: 13 Post(s)
Even easier since you won't have to wire in a relay. It's as easy as it gets.
Buy a basic on/off switch, 3/4" self tapper screws, a pack of blue scotchlok tap connectors, some 16AWG wire (black or blue, maybe?). Locate blue wire in fan harness (somewhere near intake elbow), insert new wire going back to switch into connector, along with fan wire. Crimp closed. Section of loom is optional. Recommend using electrical tape to prevent corrosion. Run wire back to or through fire wall (use existing pass-thru wire if equipped). Mount switch at position of your choice, connect fan wire to one pole, connect other to ground somewhere under dash with self tapping screw. Done.
Did I miss anything?
joeshmoe is offline
