What did you do to your 6.0 today? - Page 6250 - Ford Powerstroke Diesel Forum
 70Likes
post #62491 of 62797 Old 10-19-2019, 06:01 PM
voodooridr's Avatar
Quoted: 1021 Post(s)
Originally Posted by mbsfield18 View Post
Is there a specific 6.4 starter that fits the 6.0's or is it any year? Also want to know the same about the trans pan and filter?
Sent from my SM-N950U using Tapatalk
Any 6.4 starter will work, I got one cheap off ebay then had the local alternator shop clean it up and go through it
The trans pan and filter from the 6.4 is a better design than the 6.0 setup
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
The Following User Says Thank You to voodooridr For This Useful Post:
mbsfield18 (10-19-2019)
post #62492 of 62797 Old 10-19-2019, 06:28 PM
Quoted: 76 Post(s)
Do you use the bolts that come with both or the originals? Just curious if everything is the same.
mbsfield18 is offline
post #62493 of 62797 Old 10-19-2019, 06:33 PM
repalmer's Avatar
Quoted: 609 Post(s)
The trans filter from 6.4 is a true filter, not just a screen. If you do it, change the inline canister ( toilet paper roll ) filter at the same time. It's just a bypass filter, but you need it there to maintain flow thru the cooler, or eliminate it completely.
I got my OEM pan from a local trans rebuilder for $20. The pan is wider where the filter sits is why you need the newer style
repalmer is offline
The Following User Says Thank You to repalmer For This Useful Post:
post #62494 of 62797 Old 10-19-2019, 06:36 PM
repalmer's Avatar
Quoted: 609 Post(s)
The starter is a direct bolt in. Use what ever bolts are cleaner. Same for trans pan. The trans gasket is reusable also
repalmer is offline
post #62495 of 62797 Old 10-19-2019, 06:45 PM
TwinExcursions's Avatar
Quoted: 178 Post(s)
Garage
Wired in Edge EAS to my Insight CTS2 to add fuel pressure gauge. Original install didn't have the EAS with the EGT sensor. Purchased a BPD fuel filter cap to mount sensor on but BPD cap was extremely tight - would not thread all the way onto filter housing. Now adding Russel fittings/line to plumb sensor from test port on fuel filter housing.
Sent from my SM-G973W using Tapatalk
05 Eddie Bauer, Studded/EGR delete, Kill Devil O-ring heads, Owdags intake manifold, BD Diesel exhaust manifold, 58v FICM, SCT with Gearheads tunes
S&B stage 2 cold air, Edge Insight CTS2 c/w EGT sensor, fuel pressure sensor, BD Diesel 7.3 fan clutch, Warn Hubs, Eaton diffs front/rear, Buckstop bumper c/w 16.5 Warn Winch
TwinExcursions is offline
post #62496 of 62797 Old 10-19-2019, 06:52 PM
Quoted: 67 Post(s)
What mounts did you use? I just redid mine with S&B.
Daystars, picked them up here from a fellow member who ended up never using them.
Doward is offline
post #62497 of 62797 Old 10-20-2019, 09:12 AM
Quoted: 13 Post(s)
Garage
Dont think I would ever eliminate inline canister filter, as long as you buy the one that looks like a toilet paper roll, not the pleated one, it does a great job of filtering the fluid, my filter seems to come out grey every time and my fluid stays pretty darn clean so leads me to think that filter is cleaning the fluid way better than any filter in the pan JMHO
Teazr is offline
post #62498 of 62797 Old 10-20-2019, 10:06 AM
repalmer's Avatar
Quoted: 609 Post(s)
If you haven't upgraded, that's the only filter you have, and it's only a bypass filter(i.e. only about 10% filtration). The one in the pan is only a screen. That's the reason for the upgrade to the 6.4 era pan. It has a true filter in the pan that filters 100% of the time, not only 10%
Some people have thought since they added a true filter in the pan, the bypass filter was no longer needed. But without it there, the fluid will take path of least resistance and just go back to the trans instead of being forced thru the cooler
repalmer is offline
post #62499 of 62797 Old 10-20-2019, 11:46 AM
mrh1282's Avatar
Quoted: 88 Post(s)
Originally Posted by jahcure04 View Post
Finally upgraded batt cables on the cheap. Used @TooManyToys findings/ instructions. Added a 1/0 cable from drivers frame rail to engine block and added a 1/0 cable from drivers + to pass + while keeping the stock 2 ga cable.
Also changed the 2 batteries.
It never started so nice since i owned it.
Sent from my LG-US996 using Tapatalk
Where can I find these instructions? I would like to make my own. What did it cost you.
Sent from my iPhone using Tapatalk Pro
2005 F250 CCSB 4x4: Edge insight CTS2 with EAS EGT probe, SCT X4 with Gearhead tunes, Blue spring mod, XDP coolant filter, Cat ELC, High idle mod, 6.4 starter, Fumoto drain valves for coolant and oil, Harpoon mod, 08+ towing mirrors, transmission pan and filter, tailgate and tail lights, 2016 rear leaf springs, Rancho RS9000XL shocks. More to come.....
mrh1282 is offline
post #62500 of 62797 Old 10-20-2019, 01:30 PM
Quoted: 83 Post(s)
Watch this vid.
Also i used welding cables i had already what you will need is a hydraulic crimper
A millatary type positive battery terminal for driver side battery
4 or more ( if you mess up) 1/0ga crimp terminal preferably pre tinned .
Also a 2ga pre tinned crimp terminal.
A 10mm x 1.25 tap to chase the hole in the block if its rusted.
10mm x 1.25 ,10mm long
Heat shrink tubing for your cables.
Id say maybe 125-175 $ but everything is more expensive in canada so price out your items first.
jahcure04 is offline
