What did you do to your 6.0 today? - Page 6207 - Ford Powerstroke Diesel Forum
 238Likes
post #62061 of 62926 Old 06-21-2019, 06:40 AM
SparkyF250's Avatar
Quoted: 3376 Post(s)
Garage
Originally Posted by mrh1282 View Post
Tuesday good turn around. Canít wait to hear the results. If itís good I might have to talk to him about mine. What about head work? Does he have someone to check them?
Sent from my iPhone using Tapatalk Pro
Good question since it's been Ford's policy to eyeball em with a straightedge and put em back on. FWIW that hasn't been a winning strategy.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #62062 of 62926 Old 06-21-2019, 06:45 AM
Cleaned the whole truck like a madman. Looks like brand new. Very rewarding to drive a clean clean truck. And redid the bedliner
cjccox98 is offline
post #62063 of 62926 Old 06-23-2019, 05:49 AM
Quoted: 84 Post(s)
Any of you have a diy sugestion for a flag pole and flagpole mount for the bed of the truck ?
Sent from my LG-H915 using Tapatalk
jahcure04 is offline
post #62064 of 62926 Old 06-23-2019, 07:38 AM
Quoted: 84 Post(s)
Well its in progress
post #62065 of 62926 Old 06-23-2019, 07:43 AM
hogbody's Avatar
Quoted: 117 Post(s)
Garage
Big change in temps after Banks techni-cooler and BPD 6.0 cooling system upgrade. Same 50 mile trip with same trailer.
hogbody is offline
post #62066 of 62926 Old 06-23-2019, 12:57 PM
letsmow10's Avatar
Quoted: 124 Post(s)
Garage
Replaced my OEM radiator with an aluminum one from Performance Radiator. I broke the nipple that goes to the degas tank a couple of weeks ago and I just couldn't get it to stop leaking. The radiator isnt polished but for the price and it only being 45 mins away I figured I would give it a try. Changed the oil and filter and the rear diff fluid. It had water in it and looked bad. Been having a little occasional clunk at take off. Im not sure this is the answer but anyway thats a whole different section and post.
Sent from my SM-G965U using Tapatalk
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes, KC Stage2
letsmow10 is offline
post #62067 of 62926 Old 06-23-2019, 01:48 PM
Quoted: 84 Post(s)
Project completed
post #62068 of 62926 Old 06-23-2019, 02:26 PM
mrh1282's Avatar
Quoted: 88 Post(s)
Originally Posted by jahcure04 View Post
Project completed
How is it mounted
2005 F250 CCSB 4x4: Edge insight CTS2 with EAS EGT probe, SCT X4 with Gearhead tunes, Blue spring mod, XDP coolant filter, Cat ELC, High idle mod, 6.4 starter, Fumoto drain valves for coolant and oil, Harpoon mod, 08+ towing mirrors, transmission pan and filter, tailgate and tail lights, 2016 rear leaf springs, Rancho RS9000XL shocks. More to come.....
mrh1282 is offline
post #62069 of 62926 Old 06-23-2019, 02:40 PM
Quoted: 84 Post(s)
How is it mounted
Like this with a sloted piece of metal
post #62070 of 62926 Old 06-23-2019, 05:46 PM
G8orFord's Avatar
Quoted: 2607 Post(s)
Garage
Lifted the cab on the mini-me. It's not a 6.0 but it does have "6" cylinders and "0" turbos (though a blower may be in its future). Just thought it was a little funny that I'd pull the little trucks cab when I pulled the engine on the 6.0. Then again the 6.0 didn't need transmission work too. Took about 4 hours in sweltering heat. Didn't think that was too bad for an old guy that hadn't pulled one of these before. Worst part was the two rear cab bolts. Had to have a helper for those.
Sent from my SM-N950U using Tapatalk
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
