What did you do to your 6.0 today? - Page 4956 - Ford Powerstroke Diesel Forum
 209Likes
post #49551 of 62894 Old 06-06-2016, 10:36 AM
Fummins Mod
junior125's Avatar
Quoted: 2225 Post(s)
Garage
fedex showed up with the remaining 2 Fox shocks, now I guess I can go ahead and plan to install them, should probably re spray pb blaster on everything
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #49552 of 62894 Old 06-06-2016, 10:50 AM
j.flow's Avatar
Quoted: 4235 Post(s)
Originally Posted by SparkyF250 View Post
Then a powerstroke must just be working folk's problems?
But we sure do love em
Of course being rich would help em not be a problem at all
I wish I was rich. Damn sure wouldn't be driving a 6.0 if I was lmao
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.flow is offline
post #49553 of 62894 Old 06-06-2016, 11:07 AM
FD_REV's Avatar
Quoted: 18 Post(s)
Garage
Battery light has been coming on. Stayed on for the past 15 hours but went off while checking codes...had none. Batteries are fine and alt is charging all though its only showing 13.5 or so. Also had to order the mounting bracket for my IPR coolant filter that I was going to mount this weekend but bracket was MIA. So I went ahead and ordered the filter tool too.
FD_REV is offline
post #49554 of 62894 Old 06-06-2016, 11:28 AM
california deplorable
john galt's Avatar
Quoted: 3175 Post(s)
check over your wiring I had a wire corroding INSIDE the insulation that caused my left bank battery to drain and the bat light to come on.
...bat light
i must still need more coffee
and maybe a bat cave
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
The Following User Says Thank You to john galt For This Useful Post:
FD_REV (06-06-2016)
post #49555 of 62894 Old 06-06-2016, 12:27 PM
powerstrokecrzy's Avatar
Quoted: 271 Post(s)
Originally Posted by nighthawk285 View Post
I still need to get a FICM tuner.......but I keep spending my money on other projects when I get it built up lol
You'll be glad you did, when you do. I think a tru trac is gonna be my next big upgrade. You been installing yours yourself? Doesn't look like a horrible task.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #49556 of 62894 Old 06-06-2016, 12:39 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 2643 Post(s)
Feedback Score: 4 reviews
I had Atlas 40 tuned on it, but took it back to stock when I did the injector swap. With the bigger injectors I knew I'd be pushing the S2 already, and with the bigger nozzles and the stock nozzle FICM tuning, it was just way too hot and smoky. Jay said the bigger nozzle files will be better for that, so it's back on the list.
Yep, did the rear last year and the front this weekend. Diffs aren't bad, just suck to do on the ground without a lift lol. The only special tools required for a carrier swap are a dial indicator to adjust backlash, a bearing puller (for the front only), and a press to get the bearings on/off. The rear is super easy since the shims are outboard of the bearings, on the front they're inboard so it takes a bit more to move the factory shims over.....I always just re-use the factory shims as a starting point and go from there.
2017 F250 CCLB KR "Nighthawk" Edition.....goodies to come.
nighthawk285 is offline
post #49557 of 62894 Old 06-06-2016, 12:45 PM
G8orFord's Avatar
Quoted: 2593 Post(s)
Garage
Originally Posted by junior125 View Post
loaded Atlas 80
I loaded Atlas 80 and the PHP 100hp Performance tune when I got them the other day. Oddly enough, my EGT's are a tad lower with daily driving than they were on the Atlas 40 and MPD. Then again, the truck doesn't seem to have the same ooommph it did with MPD so that's probably why. I haven't towed anything yet though.
ON the subject of the FICM tuner. I saw there were strategies for 2003, 2004 and 2005+ in the tuner. Does it make a real difference which one you use? I used the 2004 since my truck is a late '04, but are there benefits to using the '03 or 05+?
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #49558 of 62894 Old 06-06-2016, 12:47 PM
Fummins Mod
junior125's Avatar
Garage
Ita only for if youre using a different ficm from another year truck
Sent from my SM-G900P using Tapatalk
Mike
2005 CCSB F250 4X4
The Following 2 Users Say Thank You to junior125 For This Useful Post:
G8orFord (06-06-2016)
post #49559 of 62894 Old 06-06-2016, 01:02 PM
portcity_gt's Avatar
Quoted: 1617 Post(s)
Pretty sure Worst case is you'll get a ficm incompatibility code if you put the wrong tune in.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #49560 of 62894 Old 06-06-2016, 01:16 PM
Mr. Crossthread
waggonerj's Avatar
Quoted: 1907 Post(s)
Garage
If I was rich, I would do 6.0 swaps on everything I had.
Justin
2005 F250 300,000 miles
ARP Studs - OEM Gaskets - Machined Heads - EGR Delete - 4" Straight Pipe Axle Dump - MBRP Up-pipes - Holder's 175/Stock Injectors - KC Stage 2 63.5mm - Custom Water/Meth Injection - Beans Diesel Sump - PHP FICM Tuner - SCT X4 - TSD Tunes - Riff Raff Boots and Clamps - Coolant Filter - Blue Spring - CCV Reroute - Custom Big 3 Upgrade - Viper Remote Start - Aluminum Radiator
Check out MPA, those guys are pretty decent
TPB!
waggonerj is offline
