What did you do to your 6.0 today? - Page 4831 - Ford Powerstroke Diesel Forum
 185Likes
post #48301 of 62879 Old 05-11-2016, 01:58 PM
powerstrokecrzy's Avatar
Quoted: 271 Post(s)
I checked just now, no exhaust leaks. Can hear it best under the truck driver side. Is it possible for a lifter to randomly stick? And can it un -stick itself
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #48302 of 62879 Old 05-11-2016, 01:59 PM
Quoted: 271 Post(s)
Im trying to up load a video to photo bucket so i can post it
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #48303 of 62879 Old 05-11-2016, 02:04 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 2643 Post(s)
Feedback Score: 4 reviews
Yes it's possible and yes it can un stick itself. If it dropped all the oil out during your oil change it could just be taking awhile to Re pump up. It's a rarity, but a possibility
2017 F250 CCLB KR "Nighthawk" Edition.....goodies to come.
nighthawk285 is offline
post #48304 of 62879 Old 05-11-2016, 02:18 PM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
Im with Nick. I would be going over all the stuff you replaced and touched if it just started after the install. Also powerbrake it slowly and listen to what happens. If it gets louder, have someone hold it at the loudest and try to find it.
toren302 is offline
post #48305 of 62879 Old 05-11-2016, 02:18 PM
j.flow's Avatar
Quoted: 4235 Post(s)
Originally Posted by nighthawk285 View Post
Why not just go back to a stock turbo?
It has a stock turbo in it with the 10 blade.
I have that ats in my garage that I pulled out to put my powermax in.
I'm going to be putting the fuel pump from my crew cab in also. I want to take this thing totally back to stock with a leveling kit. It'll be nice to have when I don't want to drive my crew cab, or put miles on my cummins.
My cummins is getting twin turbos right now, I was trying to hold the secret lol. So having a stock truck will be nice to just have around.
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.flow is offline
post #48306 of 62879 Old 05-11-2016, 02:21 PM
Mr. Crossthread
waggonerj's Avatar
Quoted: 1905 Post(s)
Garage
How could you keep that from us?
Justin
2005 F250 300,000 miles
ARP Studs - OEM Gaskets - Machined Heads - EGR Delete - 4" Straight Pipe Axle Dump - MBRP Up-pipes - Holder's 175/Stock Injectors - KC Stage 2 63.5mm - Custom Water/Meth Injection - Beans Diesel Sump - PHP FICM Tuner - SCT X4 - TSD Tunes - Riff Raff Boots and Clamps - Coolant Filter - Blue Spring - CCV Reroute - Custom Big 3 Upgrade - Viper Remote Start - Aluminum Radiator
Check out MPA, those guys are pretty decent
TPB!
waggonerj is offline
post #48307 of 62879 Old 05-11-2016, 02:21 PM
Bump To Pass!!
toren302's Avatar
You can put as many turbos as you want on that Cummins.....it will still sound like a bulimic lumberjack puking....and I will still most likely be able to beat it in a quarter run!! Oh wait I forgot your tires are too expensive for that.....
toren302 is offline
post #48308 of 62879 Old 05-11-2016, 02:26 PM
darkpassenger's Avatar
Quoted: 1213 Post(s)
You told us I thought you were joking though.
He told us!
Lmfao 😂😂😂😂😂
Sent from my Note 5
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #48309 of 62879 Old 05-11-2016, 02:27 PM
Quoted: 271 Post(s)
Ok, was just out there. Barely hear it at idle. Did high idle and you can hear it but a min or 2 into it the sound toned down a little, but was still there.
Also, you can hear it back at the exhaust, coming out the pipe. Not super loud, but there.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #48310 of 62879 Old 05-11-2016, 02:29 PM
j.flow's Avatar
Just incase you hadn't seen the overall standings yet 😉
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.flow is offline
