What did you do to your 6.0 today? - Page 4644 - Ford Powerstroke Diesel Forum
 37922Likes
post #46431 of 62467 Old 04-10-2016, 01:26 PM
portcity_gt's Avatar
Quoted: 1617 Post(s)
Originally Posted by j.mo View Post
So the remedy for that is what? Drill the hole out?
No there's not enough meat on the starter, just put a smaller bolt in it. I'm pretty sure it's the same size as the 6.0 top two bolts if I remember right.
darkpassenger likes this.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #46432 of 62467 Old 04-10-2016, 01:58 PM
zogger's Avatar
Quoted: 17 Post(s)
What did you do to your 6.0 today?-uploadfromtaptalk1460325491150.jpg anyone have any suggestions for replacing these lenses?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
zogger is offline
post #46433 of 62467 Old 04-10-2016, 02:23 PM
JER-1's Avatar
Quoted: 18 Post(s)
Originally Posted by partyman97_3 View Post
I just got done replacing the seals in my front axle. That turned into a little more of a job than I anticipated. I was leaking from the inner seal on the passenger side. When I took the brake calipers off I noticed they were stuck. So I cleaned up and greased them. The 4 wheel drive quit a while back, I was hoping it was maybe a seal or something, but no luck, so I guess I will keep looking.
Reference 4x4 not working
If a 6.0 probably your vacuum lines or line.vacuum turns them on off.
You have a little pump up on passenger side under hood , sometimes that vacuum pump goes bad.
JER-1 is offline
post #46434 of 62467 Old 04-10-2016, 02:28 PM
partyman97_3's Avatar
Quoted: 887 Post(s)
Garage
The pump does run. Does the the solenoid, I think they call it pvh go bad very often? I was thinking about ordering one. If I do get one, should I get it from ford or is aftermarket ok?
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #46435 of 62467 Old 04-10-2016, 02:32 PM
Fummins Mod
junior125's Avatar
Quoted: 2191 Post(s)
Garage
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #46436 of 62467 Old 04-10-2016, 03:11 PM
Gadgetguru's Avatar
Quoted: 523 Post(s)
Garage
Originally Posted by powerstrokecrzy View Post
Got these put in the other day. I like the look a lot better than having that sct hanging there, which it never did, stayed in the console, just the suction cup and wires usually.
How much boost you plan on running?
Boog likes this.
- Michael
- If being an NCO was easy, we'd be called Officers.
2017 F350 Lariat DRW
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
Traded 01SEP18 '11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Ford diesel documents
Gadgetguru is offline
post #46437 of 62467 Old 04-10-2016, 03:13 PM
darkpassenger's Avatar
Quoted: 1213 Post(s)
^^^What he said ^^^
Sent from my SM-N920T using Tapatalk
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #46438 of 62467 Old 04-10-2016, 03:19 PM
Fummins Mod
junior125's Avatar
Garage
ALL OF IT
Gadgetguru, john galt and j.flow like this.
Mike
2005 CCSB F250 4X4
post #46439 of 62467 Old 04-10-2016, 03:21 PM
california deplorable
john galt's Avatar
Quoted: 3123 Post(s)
Originally Posted by NYC F-350 View Post
no but it was somewhere back east price was 65 bucks for both if i remember right. will include old pic of engine bay after i first cleaned it up at bottom of post...if drag and drop works
I have the tri pilar AND my cts ... i can get a bit obsesive
I have a short in the harness between my 4x4cm and the switch...
i dont do wiring very well but have a local friend who is going to help me replace it when we can get his day off match up...
in the mean time for winter I have it set so if i lock the hubs i am in 4x4 and yes the rest is still spinning and needs to be addressed here in the next week or so
Name:	motor in 2014.jpg
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #46440 of 62467 Old 04-10-2016, 03:24 PM
I was looking at them before I got the bpd setup. Eventually wanting to do a bypass. Can I go with this? , even though I already have the bpd filtration that comes with the oil cooler. Or should I just go with the bpd setup?
http://www.nucmotorsports.com/fordparts.html
john galt likes this.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
