What did you do to your 6.0 today? - Page 4333 - Ford Powerstroke Diesel Forum
 185Likes
post #43321 of 62879 Old 02-07-2016, 04:17 PM
j.flow's Avatar
Quoted: 4235 Post(s)
Originally Posted by junior125 View Post
you replaced your external cooler right?
On the ex cab yes, and still had these same bull**** Temps.
Sent back to warren, supposed to be fixed, put in my crew cab, removed a perfectly good 70k mile trans, and same old ****. It hit 186* yesterday driving in town.
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.flow is offline
post #43322 of 62879 Old 02-07-2016, 04:18 PM
Fummins Mod
junior125's Avatar
Quoted: 2225 Post(s)
Garage
I've seen 180 in town with my truck in stop and go traffic, how long have you been at 70?
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #43323 of 62879 Old 02-07-2016, 04:20 PM
j.flow's Avatar
It had been about 15 miles.
I just don't understand why it runs so much warmer than the factory trans. If it's normal and not a damaging issue then that is fine. I just want to make sure that this thing doesn't **** the bed on me in 30k miles because of the increased Temps
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.flow is offline
post #43324 of 62879 Old 02-07-2016, 04:22 PM
partyman97_3's Avatar
Quoted: 906 Post(s)
Garage
Originally Posted by seijirou View Post
Toolbox, finally.
I like the 3 feet of extension. Ok, maybe not 3 feet, but a bunch.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #43325 of 62879 Old 02-07-2016, 04:23 PM
backhoebill's Avatar
Quoted: 1273 Post(s)
Send a message via Yahoo to backhoebill
Anyone else think this is excessive for trans temp? Going 70mph on the hwy. My stock trans would be in the 150s range, maybe, 160
Also not sure if I'm comfortable with that voltage. I don't know when the batteries were done so I'm going to do those as well.
My trans never exceeded 168* pulling a 15,000lb trailer full of crap through the Sierras last week. Stock trans with 237,000 miles.
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
The Following User Says Thank You to backhoebill For This Useful Post:
j.flow (02-07-2016)
post #43326 of 62879 Old 02-07-2016, 04:26 PM
Fummins Mod
junior125's Avatar
Garage
Man idk, ill ask the guy that built mine, rolling down the highway mine doesnt run 180 and I run 85 on the highway
Mike
2005 CCSB F250 4X4
post #43327 of 62879 Old 02-07-2016, 04:55 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Tranny temp seems high. mine in the 03 is a Warren and it runs around 168 to 172. As for your ect and eot why are they backwards.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #43328 of 62879 Old 02-07-2016, 05:11 PM
G8orFord's Avatar
Quoted: 2590 Post(s)
Garage
Did he change the temp sensor when he had it back? I wonder If maybe it's biased? Have you looked at the temp at startup? Is it close to oil and coolant temp? Do you have a red dot thermometer to check the pan temp once it's warmed up? My stock trans runs in the 165 range at highway speeds unloaded.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #43329 of 62879 Old 02-07-2016, 05:14 PM
j.flow's Avatar
I have the bpd hd oil cooler. It takes a little time for my oil to warm up.
I get the same Temps as you guys with my stock trans. In my last 2 trucks. Always run in the 150s. Highest I've ever seen mine was 163 and that was towing.
This warren has always run high and was part of the reason it was pulled and sent back. Andy said all was well except a sticking direct solenoid but I have about 65 Miles on it since back in and aprears to be the same song and dance.
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.flow is offline
post #43330 of 62879 Old 02-07-2016, 05:17 PM
j.flow's Avatar
What has your new trans between running on the highway and in town.
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.flow is offline
