What did you do to your 6.0 today? - Page 3731 - Ford Powerstroke Diesel Forum
 199Likes
post #37301 of 62890 Old 09-22-2015, 07:04 PM
Mitch
thebierguy's Avatar
Quoted: 110 Post(s)
Installed some Gatorback mud flaps on the front. Still have to do the back.
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #37302 of 62890 Old 09-22-2015, 08:00 PM
'consent of the governed'
Patriot's Avatar
Quoted: 2215 Post(s)
Garage
Originally Posted by toren302 View Post
To answer this in an informative sort of way...
Thank you for that. IIRC from helpful people such as yourself, I'm probably in good shape since my pressure took a while to even register a few psi and it never spiked and stayed around 7 psi. 10,000 pounds empty and floored. I hope.
Patriot is offline
post #37303 of 62890 Old 09-22-2015, 08:12 PM
JesseKK's Avatar
Quoted: 90 Post(s)
Garage
Installed an 8in Rize Industries 4 link
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #37304 of 62890 Old 09-22-2015, 08:26 PM
j.flow's Avatar
Quoted: 4235 Post(s)
To answer this in an informative sort of way....
It is a closed and sealed system (short of the cap being bad). It should hold pressure until it is vented somehow. Now the question becomes what vents it. Well there is really only a few ways. The cap, the owner taking the cap loose, or a leak. The leak on a 6.0 is the most common, and only really 2 things. One being the good ol EGR cooler. The other being the HG. What interesting about the HG issue is that its RARE to consume coolant from a HG leak on a 6.0 or 6.4. However they will slowly vent the pressure off through a bad HG when let to sit overnight. Now a waterpump that's also on its way out can cause a leak as well as obviously a hose or radiator. However the most common seem to be the coolers and HG. Now a hot engine cooling down will lower the pressure in the system as the coolant cools down and contracts back to the cool'd size it was. The Expansion of the coolant when heated up should be the ONLY pressure in the system. Anymore and you have an issue. This is why the WOT coolant pressure tests show soooo much bad news. HG leaks start REALLY REALLY small and grow the more they are driven. In other words you should always have pressure in the system unless you vent it or have an issue.
My next truck will be a 24v cummins LOL. They get the dog sh!t beat out of them and run for 350k miles on unicorn piss. Aside from having to rebuild a $2500 trans
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.flow is offline
The Following User Says Thank You to j.flow For This Useful Post:
SixCardCharlie (09-22-2015)
post #37305 of 62890 Old 09-22-2015, 08:38 PM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
Originally Posted by j.mo View Post
My next truck will be a 24v cummins LOL. They get the dog sh!t beat out of them and run for 350k miles on unicorn piss. Aside from having to rebuild a $2500 trans 10 times in the 350k period and replace everything in the cab
Fixed it for you
toren302 is offline
post #37306 of 62890 Old 09-22-2015, 08:44 PM
Fummins Mod
junior125's Avatar
Quoted: 2225 Post(s)
Garage
don't forget the front end needing replaced 2 dozen times because it's looser then a [email protected]
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #37307 of 62890 Old 09-22-2015, 08:57 PM
JesseKK's Avatar
Quoted: 90 Post(s)
Garage
^ haha oh so tru
JesseKFK
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
KCCO
JesseKK is offline
post #37308 of 62890 Old 09-22-2015, 09:49 PM
Maxxforce365's Avatar
Quoted: 14 Post(s)
Fuk ya man bet it looks badass. Got any pics?
[email protected]_forces
2015 Platinum F350 CCLB[/B]
EPA Delete Tuned by PIP
Fabtech 12" 4 Link Airdog II
04.5 F350 CCLB 4/04-7/25/15
MTW S2 Warren 175/30s Tuned by Gearhead
ARPs with OEM gaskets
Sinister Regulated Return AirDog II Beans sump
2012 Door Panels Fully Functional
Warn 12k winch
Fab Fours Front and Rear bumpers
Maxxforce365 is offline
The Following User Says Thank You to Maxxforce365 For This Useful Post:
JesseKK (09-23-2015)
post #37309 of 62890 Old 09-23-2015, 02:59 AM
Snake's Avatar
Quoted: 47 Post(s)
Originally Posted by kafleming19 View Post
Glad you haven't had issues. How many miles on them now? Have you towed 10k+ with them yet?
16,000 miles on them, and that's a fair question on the towing. I haven't had a chance to test these out under frequent, heavy loads.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #37310 of 62890 Old 09-23-2015, 03:24 PM
Weberman3's Avatar
Quoted: 650 Post(s)
Send a message via MSN to Weberman3
I clean the EBP sensor.
2004 F350 XLT 6.0L ZF6 CCSB
ARP Head Studs, EGR Delete, 4" Turboback, Fuel Sump, Coolant Filter, NUC Oil Bypass Filter
Kenwood DDX372BT with Rear View Camera, Rockford Fosgate P1683 speakers, Infinity REF1200 subwoofers
Weberman3 is offline
