2004 6.0 trans flush - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By bismic
post #1 of 9 Old Yesterday, 06:16 PM Thread Starter
Ok so I’ve been reading around a lot. I understand I need to change the cartridge filter and inline filter in the trans pan. Now computer says I need to change fluid at 15 qts. What would people use. I’m a huge amsoil guy and I’ve also heard that people use the 08’ trans pan. Any help would be nice.
Matt4124 is offline
post #2 of 9 Old Yesterday, 07:00 PM
kcoyner's Avatar
Quoted: 218 Post(s)
Order the toilet paper filter for the '04. Order an '08 pan and '08 filter. Order 15 qts of Amsoil trans fluid. When you get everything have at it. That's what I did. I can't remember the exact amount I refilled with but I think it was 12 qts(?). Anyhow, I have north of 348K on my trans now.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #3 of 9 Old Today, 07:14 AM Thread Starter
k
Replace the inline filter?
Matt4124 is offline
post #4 of 9 Old Today, 12:48 PM
kcoyner's Avatar
Quoted: 218 Post(s)
That's the "toilet paper" filter.
k
kcoyner is offline
post #5 of 9 Old Today, 01:24 PM
voodooridr's Avatar
Quoted: 1063 Post(s)
3C3Z-7B155-BA and get the o-ring too 3C3Z-7J126-AA
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #6 of 9 Old Today, 01:59 PM
Quoted: 472 Post(s)
The entire volume of transmission fluid is around 19 quarts. Just by draining the pan through the drain plug will get a little over 8 quarts out. Dropping the pan will get another quart or so out.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #7 of 9 Old Today, 02:46 PM
kcoyner's Avatar
Quoted: 218 Post(s)
WOW!! I've got to check my notes. There is some procedure that escapes me at present that purges another qt or 2? Maybe something to do with the trans cooler? I did it when I went to the Mag HyTech pan. Maybe that holds a little more as well.
k
kcoyner is offline
post #8 of 9 Old Today, 04:15 PM Thread Starter
So more then likely I won’t be able to get all of the fluid out.
Matt4124 is offline
post #9 of 9 Old Today, 05:57 PM
Quoted: 472 Post(s)
The torque converter is not drainable
kcoyner likes this.
Mark
No-start thread:
bismic is offline
