Ipr readings - Ford Powerstroke Diesel Forum
 11Likes
post #1 of 19 Old 01-27-2020, 12:22 PM Thread Starter
Quoted: 5 Post(s)
Ipr readings
Hi everyone, 2006 6.0 crewcab, I need some help just had Brand New O-ring heads installed, stage two cam, lifters, pushrods ,the whole front cover kit, injectors, manifolds, up pipes, radiator, truck is deleted, 4 inch mbrp exhaust turbo back, My question is my ipr hits 85% sometimes at half throttle and all the time at WOT, should the IPR ever hit 85% under any circumstances the ICP readings are usually around 3200 at wot, thanks
Rm762 is offline
post #2 of 19 Old 01-27-2020, 12:41 PM
Quoted: 527 Post(s)
Garage
Nope -- got a leak or your tune is messing with the numbers
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #3 of 19 Old 01-27-2020, 01:52 PM Thread Starter
Quoted: 5 Post(s)
Stock tuning
Rm762 is offline
post #4 of 19 Old 01-27-2020, 02:08 PM Thread Starter
Quoted: 5 Post(s)
There have been a couple of times where I go to get on it and it hesitates and there’s no power almost like it has a carburetor issue sort of that feeling
Rm762 is offline
post #5 of 19 Old 01-27-2020, 02:54 PM
kcoyner's Avatar
Quoted: 222 Post(s)
Yep... souunds like you've got a leak. You said "just had" so I'm guessing you had the work done by a shop. In that case I would be on the phone and letting the shop know that there is most likely a leak in the high pressure oil system. Take the truck back in and have them air test and trouble shoot the system.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #6 of 19 Old 01-27-2020, 03:27 PM Thread Starter
Quoted: 5 Post(s)
If I had a leak would I have difficulty with cold/hot starts? Like a high pressure leak or would u talking about a different leak? Sorry just trying to understand this. I forgot to mention updated stand pipes and dummy plugs, stc fitting and HHC nipples and o rings those were all installed , it starts right up like a new truck hot or cold, Hope this helps
Rm762 is offline
post #7 of 19 Old 01-27-2020, 03:49 PM
Quoted: 527 Post(s)
Garage
well, if not a leak the other possibilities are sticking IPR or the HOPO is not capable of delivering the demand
the IPC sensor is the "feedback" for the oil demand -- using a gauge is the only way to trust those readings
(possibly another ICP sensor to compare readings)
then comparing desired vs actual oil pressure
The readings indicate that the PCM want more oil and it is not delivered
it requires testing to see where the problem lies
General note:
Hydro is online now
post #8 of 19 Old 01-27-2020, 04:04 PM Thread Starter
Quoted: 5 Post(s)
Thank you, I’m going to order a new icp and ipr valve tonight also banjo bolts and blue spring kit, as soon as I get them installed I’ll let u know what happened, thanks for the help much appreciated
Rm762 is offline
post #9 of 19 Old 01-27-2020, 04:19 PM
joe blow's Avatar
Quoted: 156 Post(s)
That's a good chunk of money for just parts changing. Wouldn't you rather find out what the problem is, incase it is related to the work your shop did?
Originally Posted by Rm762 View Post
Thank you, Iím going to order a new icp and ipr valve tonight also banjo bolts and blue spring kit, as soon as I get them installed Iíll let u know what happened, thanks for the help much appreciated
kcoyner, jokester00 and Hydro like this.
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #10 of 19 Old 01-27-2020, 04:55 PM Thread Starter
Quoted: 5 Post(s)
He has already hooked up shop air to it with nothing coming from it, With all the parts that I have changed already which there’s a lot that I’m forgetting but if I replace these last four things that’s pretty much everything besides the turbo And the hpop. I have only have the truck for two years so I have no idea when the last time these parts were replaced anyway. Could a fuel issue cause the high ipr readings?
Rm762 is offline
