Thoughts on Rebuilding/Replacing injectors? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Nickjames525
post #1 of 6 Old 01-19-2020, 07:48 PM Thread Starter
Whats everyone's thoughts on OEM reman vs reman service vs home reman for injectors? I saw that there are now spool valves available on the market, along with the option to get the other moving parts as well as O-rings. I have a #2 injector that needs replaced, and #8 has already been replaced, so I really think replacing the set would be best, but I am tight on cash. What are yalls thoughts on changing spool valves and o-rings? Would run me about $350 to replace all 8 spool valves and o-rings
No_Dude is offline
post #2 of 6 Old 01-19-2020, 08:04 PM Thread Starter
If I decide against a rebuild here at home, I was thinking SoCal Diesel for my rebuild, and would run me around $750 for all 8. So far I havent found anything bad surrounding SCD other than one bad batch of duramax injectors they had back around 09
No_Dude is offline
post #3 of 6 Old 01-19-2020, 08:16 PM
ChrisSki's Avatar
Quoted: 595 Post(s)
Have not done injectors yet, but when the time comes, OEM remains. I do not want extra power, am not tuned, and I see a lot of posts about an occasional bad injector from a non-OEM place. Also, I think I have stiction, but never really gets cold enough in AZ to be sure. Iím sure at 15 years and 193k miles, that the injectors need more than just spools and External O-Rings.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 6 Old 01-19-2020, 08:17 PM
Quoted: 38 Post(s)
I’ve installed hundreds of ford remans over the years and have seen less than a 1% failure rate. I’ve also removed dozens and dozens of aftermarket stock rebuilt injectors for being garbage. Misfiring, hpop leaks, etc.
You’re better off replacing the 1 with a ford reman and saving up for the remaining 6.
bismic likes this.
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
post #5 of 6 Old 01-19-2020, 08:35 PM
kcoyner's Avatar
Quoted: 219 Post(s)
OEM remain is the ONLY option IMO. I wouldn't go with anything else unless you're looking to replace all 8 and make some big power. That's the only reason I'd take a chance on one of the aftermarket injector builders.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #6 of 6 Old 01-20-2020, 03:50 AM
Chadmills's Avatar
Quoted: 34 Post(s)
if I was in your position and didn't have the cash flow for the set of injectors, I would just replace the bad injectors with oem as they go bad.
I did mine 4 at a time..
With all that said the you tube videos make it look super easy to rebuild..👍
2005 f 350 scsb exhaust kc stage1 SCT with idp custom tunes, edge cts2 with egts,fuel and degas pressures, bd uppipes, blue spring kit, 6.4 banjo bolts bpd water pump and 7.3 fan clutch, studded with fel pro head gaskets, kdd heads
Chadmills is offline
