03-e04 Air Filter Assembly vs later model; K&N - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 10 Old 01-17-2020, 09:46 AM Thread Starter
gephro's Avatar
Quoted: 6 Post(s)
Garage
The truck I have has a K&N cold air intake on it. Personally, I'm not a fan of K&N and would prefer to switch back to OEM. So the question is - I see lots of >=L04 ones, but no 03-e04 ones out there (at least at the moment - I'm looking for used ones). Is there a difference or can I get away with a >=L04?
K&N fans - I'm sure these filters are awesome. I'm just not tough enough for one
Thanks
-gephro
2004 F-350 6.0 PS 4x4 SRW SC
gephro is offline
post #2 of 10 Old 01-17-2020, 09:56 AM
voodooridr's Avatar
Quoted: 1084 Post(s)
Some of the early air inlet tubes (filter to turbo) were one piece
Later ones were two pieces
As long as you get everything all the way to the turbo you should be fine
Sent from my SM-G960U using Tapatalk
gephro likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 10 Old 01-17-2020, 09:56 AM
Heavy_GD's Avatar
Quoted: 3170 Post(s)
Garage
Feedback Score: 4 reviews
Hey K&N fans, they are garbage.
@[email protected] help the man out if you have any leads
JustinOOO9 and gephro like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #4 of 10 Old 01-17-2020, 11:40 AM Thread Starter
gephro's Avatar
Quoted: 6 Post(s)
Garage
Perfect - thank you.
-gephro
gephro is offline
post #5 of 10 Old 01-17-2020, 06:34 PM
ZMANN's Avatar
Quoted: 4035 Post(s)
is anyone in the " know" a K&N fan ?
i have seen firsthand results and lab test that really show how crappy their washable cotton media filters are in most all applications
even pre oiled and new they can dust your motor
6.0 flush pdf
ZMANN is offline
post #6 of 10 Old 01-17-2020, 08:40 PM
Quoted: 1470 Post(s)
I don't have any leads on used. Only new, and S&B are the best priced.
https://cncfab.us/i-30498061-sb-filt...f-75-5070.html
www.cncfab.us
ZMANN likes this.
post #7 of 10 Old 01-18-2020, 03:43 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 964 Post(s)
Feedback Score: 3 reviews
If Ford did anything right it was using that Donaldson air filter for that truck. It can hold more dust/dirt and flow better than anything aftermarket.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #8 of 10 Old 01-18-2020, 05:01 AM
G8orFord's Avatar
Quoted: 2614 Post(s)
Garage
I happen to know someone who has a 99% complete '04 setup, including an almost new filter. It's used & worn and I'm pretty sure there was one grommet that had to be used with the S&B intake along with the MAF/IAT sensor.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #9 of 10 Old 01-20-2020, 06:12 AM
kcoyner's Avatar
Quoted: 222 Post(s)
For what ever reason (most likely a severe lack of patience) I just couldn't get my stock air filter removed without the SOB just fighting me every time I needed to remove it. For that reason I purchased a used Banks air filter with the oiled media. it's worked great for 213K miles now. It's always clean as can be on the inside and the air inlet is always clean. I service it every 15K or so.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #10 of 10 Old 01-22-2020, 04:54 PM
Quoted: 15 Post(s)
Garage
I have to check but I think I put my original 03 air cleaner setup in the rafters of the garage with my original exhaust system, both have less then 25k on them but havent looked at them in probably over 10 years. If you still havent found one let me know and I will get my son up there to check. I hated touching the original filter setup and went with a BRUTE FORCE cold air because it had a dry filter and oil can screw up MAF sensors quickly. Its been problem free so far.
Teazr is offline
