Runaway, due to neglect - Ford Powerstroke Diesel Forum
 15Likes
post #1 of 30 Old 01-12-2020, 10:32 PM Thread Starter
Recently I experienced a runaway. I was driving home when I lost all throttle control, I pulled over and turned the truck off. once I turned it off it begun to rev out of control. It was blowing straight white smoke, then a white and black smoke(or it appeared black it was late in the afternoon). It ran until it blew itself up (I'm guessing I'm not too positive what happened.) I brought the truck home and inspected it the next day. I found that my turbo wheel had a lot of slack. I asked a mechanic I know and he said that the turbo seals went bad and that's what caused it to run away. I don't have too much experience with diesel. If anyone who could give me a better idea of what damage may be done I would appreciate it. I would like to repair it myself.
Name:	hood after runaway.JPG
p_stpierre is offline
post #2 of 30 Old 01-13-2020, 02:33 AM
ZMANN's Avatar
Quoted: 4034 Post(s)
so you must have gathered a true runaway is a motor that has an issue and it has replaced the diesel fuel for motor oil from the engine thru the intake as it's fuel source
it will rev as fast as it can pull the oil thru whatever the failure point is
the results can be catastrophic since there is no way the electronics can prevent an over rev
6.0 flush pdf
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
p_stpierre (01-13-2020)
post #3 of 30 Old 01-13-2020, 03:18 AM
Quoted: 37 Post(s)
I canít comment on the damage, really wouldnít know until someone started troubleshooting it to see...
I wanted to mention, I used to have a 2004. I had a butterfly gate valve on the intake that was operated from the cab. It was an emergency shut down in case of runaway. It was mandatory on a lot of oil and natural gas fields. It was spring loaded, so if you pulled the handle, it shut the intake down and could not be re opened unless you reset the mechanical switch on the valve body. It worked well, and shut it down immediately.
Anyway, just an FYI.
Good luck with it.
~Support them, they support you with a blank cheque~
2004 F-350 SCSB
2010 F-350 CCSB Cabelaís
1996 F-250 RCLB 351
Jeff-F350 is offline
post #4 of 30 Old 01-13-2020, 03:30 AM Thread Starter
thank you, defiantly gonna do this on my next truck
post #5 of 30 Old 01-13-2020, 03:32 AM
ZMANN's Avatar
a lot of industries now require automatic air shutoff since so many operators leave their trucks running and unattended
a motor melt down and subsequent hot spot could cause a catastrophic chain reaction
Jeff-F350 likes this.
6.0 flush pdf
ZMANN is offline
post #6 of 30 Old 01-13-2020, 11:54 AM
dracula4999's Avatar
Quoted: 11 Post(s)
Good luck with it.
Do you happen to know who makes this kit or where to purchase one? I've never heard of them before, but sounds like good insurance to me.
2002 7.3 CCSB 4x4 XLT. 4" exhaust, wicked wheel, hydra tuner, 6637 filter mod.
Sold 2004 6.0 CCSB FX4 Lariat. 5" exhaust, KC stage 2 turbo, airdog fuel pump, CAI, head studs, EGR delete, 6" lift
dracula4999 is offline
post #7 of 30 Old 01-13-2020, 01:07 PM
Quoted: 37 Post(s)
Iím sorry, I donít remember.
2004 F-350 SCSB
1996 F-250 RCLB 351
post #8 of 30 Old 01-13-2020, 02:10 PM
Quoted: 159 Post(s)
You buy one of the older 6.0 elbows with the butterfly throttle and set it up with an old style throttle or choke control cables.
The intake butterfly is how I shut down the Jimmy 2-stroke in my 1956 Allis dozer.
But there are commercial setups, something could be adapted if not already existing.
https://www.carid.com/ic/pacbrake/items/c50145_1.jpg
Jack
Former Vehicle Test Manager, Friction Products.
03 F350SC 4x4 6.0 Auto 5/30/03
YouTube Videos - TooManyToys
Never buy a Ford Remanufactured motor
TooManyToys is offline
post #9 of 30 Old 01-13-2020, 02:39 PM
Quoted: 11 Post(s)
My 1980's ford tractor uses a butterfly to shut it down too. Never thought about adapting it to a truck just incase there is ever a runaway. Something I'll have to look in to one day.
post #10 of 30 Old 01-13-2020, 03:01 PM
Quoted: 37 Post(s)
Hereís a few. Looks similar to what I had, but these look like they are engaged by an actuator. Reading on them though, they say there is a manual option for it as well. Personally, Iíd prefer manual, for a bad day when there is no electric power.
https://www.dieselpowerproducts.com/...werstroke.aspx
https://www.actiontrucks.com/other-p...pe%5B%5D=16601
https://www.bcdiesel.ca/en/bd-positi...ford-2003-2007
2004 F-350 SCSB
1996 F-250 RCLB 351
Tags
6.0 , runaway
