wot fuel pressure loss - Ford Powerstroke Diesel Forum
 12Likes
post #1 of 17 Old 12-31-2019, 01:12 PM Thread Starter
Neeks6.0's Avatar
hey i got a 2004 6.0 and i'm having a problem in overdrive where my fuel pressures at about 50psi when i open her up alil the fuel pressure drops to like 10 psi and the truck just stays still my boost psi goes up but the truck doesn't go anywhere i replaced the pump and have a blue spring kit in any idea what could be causing the issue. i'm running a mild panty dropper tune also.
Neeks6.0 is offline
post #2 of 17 Old 12-31-2019, 02:41 PM
BTL
BTL's Avatar
Quoted: 223 Post(s)
Not enough fuel pump.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4” SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8” draw tube
BTL is offline
post #3 of 17 Old 12-31-2019, 02:43 PM Thread Starter
Neeks6.0's Avatar
i replaced it tho could there be anything else ?
Neeks6.0 is offline
post #4 of 17 Old 12-31-2019, 03:07 PM
Quoted: 512 Post(s)
lol - I guess I missed the fuel pump replacement in the first post also!
You didn't mention fuel filters, but I am guessing you replaced those? Are you sure that the gauge is accurate?
It could be that something went wrong w/ the blue spring install, but no way to say for sure over the internet. You may have to get a pressure profile from the pump discharge to the regulator to find out where the pressure loss is.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #5 of 17 Old 12-31-2019, 04:08 PM Thread Starter
Neeks6.0's Avatar
yeah i replaced the filters as well, sorry i didn't include that but yeah maybe the sensor i will get one shipped out i just can't figure out what could make the truck lag like that in overdrive
Neeks6.0 is offline
post #6 of 17 Old 12-31-2019, 04:16 PM
Quoted: 512 Post(s)
Excessive smoke?
How about fuel tank level?
jokester00 likes this.
Mark
No-start thread:
bismic is offline
post #7 of 17 Old 12-31-2019, 04:30 PM
letsmow10's Avatar
Quoted: 124 Post(s)
Garage
Stock size injectors?
Sent from my SM-G965U using Tapatalk
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes, KC Stage2
letsmow10 is offline
post #8 of 17 Old 12-31-2019, 05:22 PM
california deplorable
john galt's Avatar
Quoted: 3181 Post(s)
o rings on either fuel filter pinched or cracked?
injectors tinkered with could be leaking at the orings..
thats about all i got that wasnt mentioned
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #9 of 17 Old 01-01-2020, 09:25 AM Thread Starter
Neeks6.0's Avatar
i recently just put new dummy plugs and standpipes in because i was holding no oil pressure cause the truck wouldn't start but my fuel pressure was messed up but it just started to do this thing in overdrive where it just wouldn't go and want to die out
john galt likes this.
Neeks6.0 is offline
post #10 of 17 Old 01-01-2020, 10:49 AM
Quoted: 527 Post(s)
Garage
I suppose it depends on where you are measuring fuel pressure -- before or after the fuel filter
but with only 10psi under load -- you have a flow problem
The 50psi is a pump or regulator problem -- blue spring should be 70
The pump should be able to put out 100psi(internal regulator) straight off the line
I would disconnect the outlet line from the pump and test pressure/flow there first
100psi deadhead and good flow open
Use a clear line with a loop in it to watch for bubbles
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
