Best diesel shops in st louis Missouri - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-15-2019, 06:56 PM Thread Starter
Brandoncaloia@gmail.com's Avatar
Looking for reliable diesel shop in around st louis Missouri area. I have a 05 f250 6.0 that has coolant in oil. Assuming bad head gaskets. But what stumpes me is theyve been done before and already have studs. Egr is deleted. Bought truck in June of this year. Guy put new radiator and water pump in it and supposedly a new oil cooler. I've put 15k miles on it since june and truck runs great. Makes.me think maybe he messed something up on the cooler or something. But you'd figure I'd have symptoms way sooner then 15k miles. Another thing is 2 weeks ago I noticed a small coolant leak right under the power steering pump,front cover
So also makes me wonder if there something up with the water pump or front cover to cause coolant to mix in the oil. Truck fires up and runs now no knocking or anything. Right after I noticed the coolant leak checked everything added some coolant amd drove it another 2 weeks until a few days ago it started to get hot then fan kicked on and cooled right back down. Took home and checked everything. Coolnt was good. Oil dipstick looked good clean oil. So I drained a little oil out of the pan just for giggles and what d you no about a 8oz cup worth of antifreeze czne out first, then fresh oil after that. Check dipstick after that slightly milky.now. any output be great. Either way its getting diagnose tomorrow. I've used stl diesel before on my last 6.0 and they were pretty good. Any other places name them! Thanks!
post #2 of 8 Old 12-23-2019, 04:33 PM
Check out super duty service
120 E Harris St
Grain Valley, MO 64029
Owners name is Anthony Heard nothing but good things about them
Rodriguez6299 is offline
post #3 of 8 Old 12-23-2019, 05:27 PM
partyman97_3's Avatar
Quoted: 913 Post(s)
Garage
@3054tony is one of our St Louis guys. Maybe he will chime in.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is online now
post #4 of 8 Old 12-23-2019, 06:49 PM
3054tony's Avatar
Quoted: 1244 Post(s)
I never used any shops but heard some good things about lin co diesel Performance in troy or if you feel like making the drive there is st. james diesel down in st. james. Also know someone that works at fas diesel Performance in st Peter's but I have never used any of them
04 f250 sold.
3054tony is offline
post #5 of 8 Old 12-24-2019, 11:51 AM
Quoted: 1466 Post(s)
Feedback Score: 4 reviews
@waggonerj You know of anyone in the area.
partyman97_3 likes this.
post #6 of 8 Old 12-24-2019, 12:13 PM
Mr. Crossthread
waggonerj's Avatar
Quoted: 1932 Post(s)
Garage
I'm in KC, but I have heard good things about lin co and st james.
Sent from my SM-A505U using Tapatalk
Justin
2005 F250 300,000 miles
ARP Studs - OEM Gaskets - Machined Heads - EGR Delete - 4" Straight Pipe Axle Dump - MBRP Up-pipes - Holder's 175/Stock Injectors - KC Stage 2 63.5mm - Custom Water/Meth Injection - Beans Diesel Sump - PHP FICM Tuner - SCT X4 - TSD Tunes - Riff Raff Boots and Clamps - Coolant Filter - Blue Spring - CCV Reroute - Custom Big 3 Upgrade - Viper Remote Start - Aluminum Radiator
Check out MPA, those guys are pretty decent
TPB!
waggonerj is online now
post #7 of 8 Old 12-24-2019, 03:11 PM Thread Starter
Yea I got it at STL diesel now had towed there Friday. Truck runs great. Just has me stumped. My.buddy works there. Thursday there gunna diagnose it and see whats up. I'll let u guys no incase this happens to anyone else.
post #8 of 8 Old 12-27-2019, 09:54 PM Thread Starter
Stl diesel in festus
Bsd oil cooler and needs head gaskets. Gsve me a quote.of 5000.$
On the high sode.tho
.hes calling me.back Monday morning to do give me an exact.price. gunna also call around some shops Monday to.compare prices. 5k us little high I tink..an oil cooler is included in doing the gaskets they said . I dud get ahiod.of fas diesel befire they closed today bc i didn't get the call from stl diesel until 4. Every.sjop.closes.at.5
.they quoted.me 4000
.an they have machine.shop for the heads in there shop and ssud they reorin them everything also..find out Monday when I csll sbout other shops
Eas.rewly lookimg.no more.them the 3500.ramge.tops
Stl diesel the owner I no
.amd.is also.calimg.me mondsy.for.an exact price. He said 5k is the high side
Especially knowimg.me.lol
.f
