Everything I’ve got done to my 6.0 - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 12 Old 12-05-2019, 08:52 PM Thread Starter
Quoted: 4 Post(s)
thus far with a 188k miles:
my failed injector #7 replaced
OEM upgraded Oil cooler including screen and seals
Blue spring upgrade kit
STC fitting upgrade kit
EGR cooler and EGR valve replacement (upgrade) I didn’t want to delete Incase I travel states
New air intake and charge pipes
Coolant filters and oil filters
Stand pipes and dummy plug
Driver and passenger side full glow plugs and harness swap
EDGE CTS2 monitor with all the wiring for my exhaust, oil and fuel pressures
Down the road I plan on bulletproofing the head bolts and head gaskets, replacing all the injectors, and upgrading my FICM and turbo.
Hopefully my truck runs better now and last until I can get everything else done. I don’t plan on hauling anything till I get the last bit of upgrades so do y’all think it’ll be okay for now?
DKTA is offline
post #2 of 12 Old 12-05-2019, 10:19 PM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
probably not
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #3 of 12 Old 12-06-2019, 04:04 AM Thread Starter
Quoted: 4 Post(s)
Originally Posted by doubleslottedflaps View Post
probably not
Why do you think that? I’ve pretty much upgraded all the failing points in the truck minus the turbo and head bolts.
DKTA is offline
post #4 of 12 Old 12-06-2019, 04:23 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
The only things certain in life are death, taxes and your 6.0 needing more money thrown at it.
BTL and hogbody like this.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #5 of 12 Old 12-06-2019, 05:18 AM
joe blow's Avatar
Quoted: 153 Post(s)
Yep....true story.
Had you bought a Toyota Camry your question would probably net the answer you are looking for.
This truck engine is finicky and temperamental.
Good Luck
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #6 of 12 Old 12-06-2019, 06:03 AM Thread Starter
Quoted: 4 Post(s)
[QUOTE=joe blow;16359845]Yep....true story.
Good Luck
I didn’t know what I got myself into when I bought the truck and then when it started to get problems I started doing my research and learned all about the 6.0. I’m already 3k in parts in it and a 1,400 FICM repair and fuse box and wiring harness repair already and ain’t gonna give up on it just hate that I haven’t got to enjoy the truck as much as I wanted too because it’s been sitting so long being worked on with what little bit of time I can spare out of my 60 hour work week.
DKTA is offline
post #7 of 12 Old 12-06-2019, 06:11 AM
Blow me to Bermuda!
nine9six's Avatar
Quoted: 83 Post(s)
Garage
Drive it and enjoy it. I can't find enough excuses to drive mine. Love it!
Justin
2016 F250 6.7 PSD Lariat CCSB FX4 -|- 2006 F350 6.0 PSD Lariat CCSB FX4 -|- 1986 F250 6.9 IDI Lariat ECLB -|- 2008 F250 6.4 PSD XLT CCSB (sold!)
nine9six is offline
post #8 of 12 Old 12-06-2019, 06:18 AM Thread Starter
Quoted: 4 Post(s)
Only thing that scares me to death about the truck is before the FICM repair and fuse box repair the truck shut off mid drive (40 mph) and I had to man handle the **** out my steering wheel so I wouldn’t hit a car and got my truck to run up on a sidewalk into an open parking lot.
Hoping that don’t happen again but my truck wouldn’t start after that and had it towed and that’s when they had to put a new FICM in and repair my burned out wiring harness and redo the entire fuse box because they said eveything blew do to a bad battery I had in the truck
DKTA is offline
post #9 of 12 Old 12-06-2019, 06:53 AM
Blow me to Bermuda!
nine9six's Avatar
Quoted: 83 Post(s)
Garage
I've been in a similar situation in my IDI. I was going through a busy intersection and making a left when the power steering pump went out. I had to strong-arm the **** out of it just to keep from taking out the people going the other direction making their left turns. Thankfully I was only a few blocks from the house and on my way there anyway.
The list of things you've done looks good to me but as mentioned: you never know with these trucks. I recently did the same items you've listed and the truck has never ran better. I'm completely smitten!
Justin
nine9six is offline
post #10 of 12 Old 12-06-2019, 10:06 AM
columbusgeek's Avatar
Quoted: 7 Post(s)
I'm in a very similar situation and look for excuses to drive it now.
Wife - "I wish we had some toothpics."
Me - "brb"
BRAAAAAAAAAPPPPPPPp KSSSSSSSSSSssssss, BRAAAAAAAPPPPPPPPPpKSSSSSSsssssss
nine9six and BTL like this.
columbusgeek is offline
