2005 f250 no crank after sct livewire ts froze - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By G8orFord
post #1 of 9 Old 12-05-2019, 12:33 PM Thread Starter
Hey all,
New to the forum but always watching and reading.
I have a 2005 f250 6.0 all stock.
I invested in a sct livewire to try and help with fuel.
When I tried to put it back to stock it froze midway through and I know get a strategy/part number could not be read error.
Spoke with sct went through all the motions online. Ended up mailing it to and my pcm to them.
They say they had no problems returning it to stock. Yet when I got it back today I get the same error.
Obd will power up tuner but go’s to the error when try and do anything.
They says it’s something with my truck not them. Take it to Ford...
I had been running autoenginuity on it before I tried to return it to stock and had no codes except fan clutch. So lost as to how it’s my truck all the sudden.
The truck will now power on all dash lights including a wrench now. It will not crank over at all.
Batts are 12.1 volts
If I pull starter cable off firewall and touch to battery it cranks over fine and strong.
Anyone with any experience with this issue.
I would greatly appreciate your input.
Thanks
Ps going to get relays tomorrow all other fuses appear fine.
Fosr34 is offline
post #2 of 9 Old 12-05-2019, 05:19 PM
7.3lf550's Avatar
Quoted: 91 Post(s)
Have more than 1 key for the thing? Very well could be the security system. If the chip in the key failed or is not being read properly the truck will not crank. This may also cause the tuner problems.
I had a key for my 03 excursion that worked for 2 years. Then one day the thing would not even try to crank. 2 Hours later i tried the other key and it fired right up. AE had no codes. And truck would crank if i jumped the wire on the firewall. Had another key made so i had a good working spare and threw the bad key in my toolbox.
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #3 of 9 Old 12-05-2019, 05:44 PM
G8orFord's Avatar
Quoted: 2592 Post(s)
Garage
The 6.0 trucks don't have PATS.
jokester00 likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #4 of 9 Old 12-06-2019, 09:51 AM
ZMANN's Avatar
Quoted: 4013 Post(s)
agreed the F trucks other than the Harley do not have a security key
6.0 flush pdf
ZMANN is offline
post #5 of 9 Old 12-06-2019, 10:02 AM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
SCT Flash tuners need a steady strong power and your batteries are just a tad weak. I would hook up a battery tender to the batteries and try again personally. Before that clean all battery terminal and ground wires first. I never had issues but my friends 05 had issues with the t2 unless his batteries were hooked to a tender. He ended up getting new batteries and problem solved for him.
I know it sounds silly but that was my only gripe with SCT unless your power supply was premium the ts specifically had freezing issues.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #6 of 9 Old 12-06-2019, 10:22 AM Thread Starter
Update.... 6.0 is alive!
Had I paid more attention to the AE fan clutch error. I wouldn’t owe sct an apology for blaming there tuner.
I guess it was coincidence that at the time I was tuning the fan clutch wire shorted out and blew the pcm maxi fuse.
The fan clutch wire was cut in half.
Having power to dash and everything else caused me to skip some basics and didn’t check every fuse I needed to.
Thanks for the replies and if nothing else maybe someone else will benefit from this.
Fosr34 is offline
post #7 of 9 Old 12-06-2019, 10:30 AM
BTL
BTL's Avatar
Quoted: 218 Post(s)
BPD Fan Clutch Wire Protector.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4” SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8” draw tube
BTL is offline
post #8 of 9 Old 12-06-2019, 10:50 AM Thread Starter
BTL
Thanks that will be ordered.
Fosr34 is offline
post #9 of 9 Old 12-06-2019, 11:39 AM Thread Starter
I had heard that so, I had hooked it up as soon as issue started.
Fosr34 is offline
