Barn Find!! - Ford Powerstroke Diesel Forum
 6Likes
  • 3 Post By bismic
  • 1 Post By bismic
  • 1 Post By bismic
  • 1 Post By nine9six
post #1 of 10 Old 12-03-2019, 06:00 PM Thread Starter
Quoted: 9 Post(s)
Barn Find!!
My buddy found a 2005 F-250 6.0 , A/T, 4WD with 56,000 miles on it. Older fella owned it and he can't drive any longer. Leather interior, body is solid.
He's already put rotors/pads all around, shocks, and changed the fuel filters.
You think it's worth $15K?
If it was easy everyone would do it!
WarEagle_PS is offline
post #2 of 10 Old 12-03-2019, 06:11 PM
Quoted: 85 Post(s)
I'd probably pay 15 for it, but I'd definitely try to talk him down, because I doubt it's been studded and such. 4 door? Got pics?
Sent from my SM-N950U using Tapatalk
mbsfield18 is offline
post #3 of 10 Old 12-03-2019, 06:14 PM
Quoted: 457 Post(s)
Crew Cab?
Long Bed/Short Bed?
Dual or single rear wheels?
Ever had a tuner?
Ever had engine work?
Maintenance records on oil and fuel filters (and type of oil)?
Still have the Gold coolant?
Stock air filter?
Stock exhaust?
Tires in good shape?
I assume it starts and runs?
How many engine hours on it?
How was it driven for 56k miles (towing, idling, etc).
Patriot, nine9six and mbsfield18 like this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #4 of 10 Old 12-03-2019, 06:17 PM Thread Starter
Quoted: 9 Post(s)
Crew Cab, Short bed, SRW, I doubt it had a tuner. The guy that owned it went into a nursing home and he towed his fishing boat with it. Tires only have about 7K miles on them but they look too small compared to the stock tires on my 07.
Not sure on service records. I assume everything on it is stock.
post #5 of 10 Old 12-03-2019, 06:27 PM
Quoted: 457 Post(s)
If everything I posted checks out, it may very well be worth it. That said, the 05's have the weak EGR cooler, and also the weak dummy plugs and standpipes. The turbo may very well be frozen (the variable inlet guide vanes on the exhaust wheel).
Also, anytime you buy a 6.0L, you need to look for signs of leaking head gaskets or a leaking EGR cooler. This is commonly evident (although not always) by signs of coolant spraying from the degas bottle cap. It will show up as "water spots" where the coolant minerals are left .... after the water and glycol evaporate.
Also, I would have a shop check out the fuel pressure - they can simulate WOT conditions for the fuel pump.
mbsfield18 likes this.
Mark
No-start thread:
post #6 of 10 Old 12-03-2019, 06:42 PM
comvet42's Avatar
Quoted: 22 Post(s)
I bought my 04 king ranch back in 2014 with 42k on it similar situation old couple towed their horse trailer. Paid a lot more than 15k so 15 donít seem to bad.
Sent from my iPhone using Tapatalk
2004 F250 King Ranch
ARP Headstuds
HD Fan Clutch
BPD Egr
BPD Heavy Duty oil cooler
Blue Spring
4" MBRP Turbo Back Exhaust
Stock Everywhere Else
comvet42 is offline
post #7 of 10 Old 12-03-2019, 06:56 PM
Quoted: 457 Post(s)
One thing is for sure from my perspective. Even if it seems like a good deal, I would be THOROUGH in checking it out.
Mark
No-start thread:
post #8 of 10 Old 12-03-2019, 07:49 PM
Vaughn715's Avatar
Quoted: 4 Post(s)
$15k for 56k miles is a steal where I’m at. Especially if you’re in a rust free area. I’d plan to save the money to do a bulletproof in the next 50k, just to be safe if she does start spewing coolant. Definitely check out the turbo and fuel and oil, but I’d buy it and drive her (gentle at first) and work out the kinks as you go. If she’s been taken good care of and you continue to do so, she will take care of you.
In fire you can plan everything out to the minute, and a minute before that everything changes.
Vaughn715 is offline
post #9 of 10 Old 12-03-2019, 08:14 PM
Blow me to Bermuda!
nine9six's Avatar
Quoted: 82 Post(s)
Garage
zsargent likes this.
Justin
2016 F250 6.7 PSD Lariat CCSB FX4 -|- 2006 F350 6.0 PSD Lariat CCSB FX4 -|- 1986 F250 6.9 IDI Lariat ECLB -|- 2008 F250 6.4 PSD XLT CCSB (sold!)
nine9six is online now
post #10 of 10 Old 12-06-2019, 06:06 PM
Blow me to Bermuda!
nine9six's Avatar
Quoted: 82 Post(s)
Garage
Justin
