Drive Shaft or Traction Bars - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By 00t444e
  • 2 Post By ZMANN
post #1 of 5 Old Today, 08:59 AM Thread Starter
comvet42's Avatar
Quoted: 21 Post(s)
Hello everyone,
I have an 04 with a 4” lift using blocks in the rear on top of factory blocks. I’m noticing what I think is drive line shutter when taking off towing or stepping on it with my SRL + tune. I did shim the carrier bearing down when I lifted the truck. just not sure if it is the carrier bearing wobbling around or if it is axle wrap from being stacked on top of two sets of blocks. I was thinking of having the one piece shaft built for it and making my own set of traction bars from what I’ve learned on the site. I’m just wondering if doing both is worth it? Or just doing traction bars with the two piece?
Sent from my iPhone using Tapatalk
2004 F250 King Ranch
ARP Headstuds
HD Fan Clutch
BPD Egr
BPD Heavy Duty oil cooler
Blue Spring
4" MBRP Turbo Back Exhaust
Stock Everywhere Else
comvet42 is offline
post #2 of 5 Old Today, 03:42 PM
00t444e's Avatar
Quoted: 594 Post(s)
Traction bars made a big difference on my truck with a 4" lift, well worth the money.
voodooridr likes this.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 5 Old Today, 03:59 PM
ZMANN's Avatar
Quoted: 3945 Post(s)
i put a go pro under mine and the traction bars hold my pinion angle dead steady
thats important to me because aggressive tires and heavy loads can really twist the springs up
HP MACHINE and voodooridr like this.
6.0 flush pdf
ZMANN is offline
post #4 of 5 Old Today, 05:27 PM Thread Starter
comvet42's Avatar
Quoted: 21 Post(s)
Thanks guys for the replies, I’ll fab some up and see where I end up.
ARP Headstuds
HD Fan Clutch
BPD Egr
Blue Spring
comvet42 is offline
post #5 of 5 Old Today, 07:58 PM
HP MACHINE's Avatar
Quoted: 485 Post(s)
Ummm ..... you forgot your lead foot
HP MACHINE is online now
