Replacing all lifters during HG job..crazy? - Page 4 - Ford Powerstroke Diesel Forum
 23Likes
post #31 of 38 Old 12-15-2019, 06:02 PM
Quoted: 84 Post(s)
Originally Posted by TooManyToys View Post
Itís a 1,000lb motor, so a 2,000lb single post should not be an issue.
But thereís lots of options. A wood frame would work. I put together a twin post using 8020 extrusions and bolting it up.
After using this twin post though, I doubt Iíll ever use my single post again.
Got Any pics ?
Sent from my LG-US996 using Tapatalk
jahcure04 is offline
post #32 of 38 Old 12-15-2019, 09:48 PM
Quoted: 159 Post(s)
Eventually, I'll make a video.
ID:	726131   Click image for larger version
Name:	Screen Shot 2019-12-16 at 12.38.55 AM.png
ID:	726133   Click image for larger version
ID:	726135   Click image for larger version
Name:	Screen Shot 2019-12-16 at 12.42.41 AM.png
ID:	726137   Click image for larger version
Name:	Screen Shot 2019-12-16 at 12.43.04 AM.png
G8orFord, jahcure04 and Hydro like this.
Jack
Former Vehicle Test Manager, Friction Products.
03 F350SC 4x4 6.0 Auto 5/30/03
YouTube Videos - TooManyToys
Never buy a Ford Remanufactured motor
TooManyToys is offline
The Following User Says Thank You to TooManyToys For This Useful Post:
jahcure04 (12-17-2019)
post #33 of 38 Old 12-15-2019, 09:56 PM
Quoted: 159 Post(s)
Some more pics.
Name:	Screen Shot 2017-10-14 at 2.43.53 PM.png
ID:	726141   Click image for larger version
ID:	726143   Click image for larger version
ID:	726145   Click image for larger version
ID:	726147   Click image for larger version
G8orFord and Hydro like this.
Jack
post #34 of 38 Old 12-17-2019, 07:15 PM
Quoted: 84 Post(s)
How much did it cost in parts vs buying say 2 1ton engine stands and welding them together ?
post #35 of 38 Old 12-17-2019, 08:24 PM
joe blow's Avatar
Quoted: 156 Post(s)
Two stands and material to weld them together (including the scrap bin finds at the metal supply) cost me 150.00 and some labor.
I had to reseal the bed plate, so I needed the ability to rotate the engine on the stand. Rotating the engine was super easy using a 4' cheater pipe over the standard turn handle supplied with the stand.
Worked out very well but I would change a few things if I had to make another.
Good Luck
Joe
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #36 of 38 Old 12-18-2019, 04:35 AM
Quoted: 159 Post(s)
For me, not much. I use 8020 aluminum extrusions like an adult erector set, reusing the pieces over and over building fixtures, tables, whatever as I need, so Iíd have to sit down and come up with what the cost would be. It would not be cheap.
If I was starting from scratch and wanted to flip the motor around spending the least amount of money, Iíd buy two HF stands (on different days to use the discount). Two 1,000lb stands would work for a rotisserie. As I said earlier, if you take the front and rear covers off while the block is suspended by the crane, you can use the existing parts. If you want to rotate around the motor mounts, you have to buy or fabricate the mount plates or something similar.
Jack
post #37 of 38 Old 12-30-2019, 07:34 AM Thread Starter
Quoted: 5 Post(s)
I wanted to run this scenario by the forum..
If I plan to do a cab on HG job while replacing the branch tube and back 4 lifters. Does anyone foresee an issue carrying out the one motor mount trick to access the passenger side cylinder head with no transmission or transfer case attached? In all cases that I have seen or read about on the internet in reference to a cab on head gasket job, the transmission and transfer case are still attached when the individual removes the driver side motor mount.
Any thoughts? I don't want to hurt or crack anything.
2006 F250 KR 4x4(09/30/05 Build Date)235k Miles-Studded, BPD Oil Cooler, CAT ELC, Scangauge II
tumbler33 is offline
post #38 of 38 Old 12-30-2019, 07:49 AM
Quoted: 527 Post(s)
Garage
You already have the tranny out?
if you remove one motor mount -- it would seem to me at that point, would be almost easier to just pull the engine
and do the heads and the other stuff out of the truck
tumbler33 likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
