What to look for when buying? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By bismic
post #1 of 5 Old 11-20-2019, 07:10 PM Thread Starter
I'm looking to buy another truck. If I"m looking at one of these trucks what should I pay attention to? Other than the standard body, frame, suspension issues.
If there is a thread on this just link me to it.
Thanks.
packratt is offline
post #2 of 5 Old 11-20-2019, 07:46 PM
ChrisSki's Avatar
Quoted: 573 Post(s)
This is an intro to a four part series
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #3 of 5 Old 11-20-2019, 08:50 PM
doubleslottedflaps's Avatar
Quoted: 182 Post(s)
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is online now
post #4 of 5 Old 11-21-2019, 03:16 AM
ChrisSki's Avatar
Quoted: 573 Post(s)
Bill may not be the most popular guy, but there is no better video out there on how to buy a 6.0. You do need to decide if the sales pitch is for you, probably not. Had I watched before I bought, it would have saved me a lot. Little things like crawling underneath to check for oil leaks to knowing the common engine problems. Since watching these videos, Iíve noticed things on other 6.0s Iíve looked at, like a FX4 bed on a two wheel drive truck, and how to check the engine. Itís not that all this info is not available elsewhere, its that it is all over the web not in one place.
Ravelco
Good 6.0 Reading:
ChrisSki is offline
post #5 of 5 Old 11-21-2019, 03:43 AM
Quoted: 402 Post(s)
https://www.ford-trucks.com/forums/9...used-6-0l.html
Spirit likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
