6.0 Powerstroke engine oil not getting dirty? - Ford Powerstroke Diesel Forum
 13Likes
post #1 of 17 Old 11-12-2019, 03:11 AM Thread Starter
I recently went through my Powerstroke and had all the heads worked over studded egr delete etc. My question is now that I did all that my engine oil is not turning black like all diesels do. I have 4400 miles on this oil change and its so clear you have a hard time seeing it on the dipstick. I run rev x in the oil and their fuel additive. Running just SCTs 70 hp tow tune all the time. What is causing it to do this so I can keep it doing that.
Thanks.
Dales Super Store likes this.
Nhart is online now
post #2 of 17 Old 11-12-2019, 08:33 AM
El_Rey_Dallas's Avatar
Quoted: 16 Post(s)
I think the egr delete is the big reason for cleaner oil. I noticed it after mine was deleted.
I also know blow-by of the piston rings is the biggest cause of carbon contamination of oil in most engines. Maybe someone else has a better hypothesis.
Sent from my iPhone using Tapatalk
El_Rey_Dallas is offline
post #3 of 17 Old 11-12-2019, 09:50 AM
00t444e's Avatar
Quoted: 594 Post(s)
What oil are you using?
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #4 of 17 Old 11-12-2019, 11:39 AM
ZMANN's Avatar
Quoted: 3944 Post(s)
interesting
do not really hear of a 6.0 with clean oil specially at 4400 miles
even with a bypass filter
hell mine is dirty looking after the first day LOL
6.0 flush pdf
ZMANN is offline
post #5 of 17 Old 11-12-2019, 02:15 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 865 Post(s)
Feedback Score: 3 reviews
Judging the oil color by the dipstick isn't a measure of how "dirty" it's gotten.
JustinOOO9 and jokester00 like this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #6 of 17 Old 11-12-2019, 02:59 PM
JustinOOO9's Avatar
Quoted: 1628 Post(s)
Garage
Oh just wait till you drain that oil lol. It will be black as black can be. It almost always looks good on the dipstick. Heck my 1999 7.3l using the cheap travelers 15w-40 conventional looks golden honey on the dipstick, then when it drained woowee... Noticed exact same thing running rotella t6 5w-40 and now currently their newer t6 15w-40.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #7 of 17 Old 11-12-2019, 05:03 PM
jokester00's Avatar
Quoted: 483 Post(s)
Garage
Get a new dipstick - it will go back to being black all over again
-jokester
bismic likes this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #8 of 17 Old 11-12-2019, 05:20 PM
Quoted: 401 Post(s)
It is a good thing when oil gets dark looking. A diesel engine is going to make soot, period. You want a diesel oil that will keep the soot dispersed and suspended in fine particles, rather than forming heavier deposits.
kcoyner, G8orFord and jokester00 like this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #9 of 17 Old 11-12-2019, 06:36 PM
Jjorgis5569's Avatar
Quoted: 70 Post(s)
Ah the oil talk. Oil lubricates, cools, and holds contaminants in suspension. In simplistic terms, think of a glass of tea as your oil. Now add sugar (contaminants), and stir. When it becomes a supersaturated mixture, sugar no longer dissolves, and you get it building up on the bottom of the glass. Thatís when you get deposits forming.
jokester00 likes this.
Jjorgis5569 is offline
post #10 of 17 Old 11-12-2019, 08:33 PM
jokester00's Avatar
Quoted: 483 Post(s)
Garage
OP - from the sounds of it, you need to add less sugar to your oil Less sugar, less deposits!
-jokester
bismic likes this.
Edge EAS EGT probe
