Ford's position on adding a ground from the body to the transmission - Page 4 - Ford Powerstroke Diesel Forum
 30Likes
post #31 of 55 Old 11-07-2019, 08:00 AM
Quoted: 145 Post(s)
Every wire, every connection has resistance. You can't get around science.
Jack
Former Vehicle Test Manager, Friction Products.
03 F350SC 4x4 6.0 Auto 5/30/03
YouTube Videos - TooManyToys
Never buy a Ford Remanufactured motor
TooManyToys is offline
post #32 of 55 Old 11-07-2019, 09:01 AM
00t444e's Avatar
Quoted: 599 Post(s)
Yes but it's a very low resistance, it isn't relevant to the conversation.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #33 of 55 Old 11-07-2019, 10:08 AM
Quoted: 145 Post(s)
It is relevant. There's still current flow, there's still the same voltage potential between the two parallel circuits. It's high school electricity.
This is a tough crowd. You want relevancy, let's go back to my earlier post. There's no conductivity between the trans, transfer case, driveshafts, axles, springs, shocks, ball joints or tie rods to the frame and it's connected body tub. If you add a cable, you are providing a pathway through the trans. I'm in a unique position to show that without the engine as the conduit there's no connection.
Edit - Bill has his head up his .......
bismic, SparkyF250 and Chris like this.
Jack
post #34 of 55 Old 11-07-2019, 11:22 AM Thread Starter
Quoted: 413 Post(s)
Very well said Jack. Thanks for contributing, but sorry for dragging you into such an emotional topic. Hard to understand why IMO.
So the bodybuilder adds a grounding cable to the frame because the block to frame straps were not sufficient enough. Adding a cable from the frame to the transmission then does the same thing afterward if not addressing the block to frame!
Ford actually says to not add a grounding strap to the transmission, but also says if the loads are high to connect a strap directly from the alternator to the frame, not going through the block and certainly not going through the transmission case.
Your post above is spot on. One has to think beyond the recommendation and get to the "why" of the recommendation.
Adding a second body unit ground to the frame when/if the existing (as designed) frame-to-block strap is an insufficient pathway just doesn't "add-up". The alternator to frame ground makes a lot of sense. IMO, so does adding another frame to block ground. Checking the condition of the existing ground wires and straps is clearly very wise (at least we can all agree on that one).
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #35 of 55 Old 11-07-2019, 11:42 AM
Quoted: 145 Post(s)
Well, you know how I get during debating a subject ......
It ain't personal, I was an only child.
SparkyF250 likes this.
Jack
post #36 of 55 Old 11-07-2019, 12:16 PM
Heavy_GD's Avatar
Quoted: 3140 Post(s)
Garage
Feedback Score: 4 reviews
Who knew you boys were so passionate about grounds.
jman37 and SparkyF250 like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #37 of 55 Old 11-07-2019, 12:57 PM
Quoted: 145 Post(s)
Those who have done three videos on the subject with a fourth coming.....
akfiremedic and SparkyF250 like this.
Jack
post #38 of 55 Old 11-07-2019, 01:36 PM
00t444e's Avatar
Quoted: 599 Post(s)
Referring to the first diagram on your attachment 1-4 is on the positive side of the load and 5-8 is on the negative. If you put one lead of a volt meter at 1,2,3 or 4 and the other lead on 5-8 your going to read 9 volts. If you test between 7 and 8 as long as the wire and connection is good you are going to read 0 volts or very close to 0, not a significant amount. If you wire a resistor in parallel between 7 and 8 and test across that resistor you are still going to get 0 volts across that resistor, because over 99% of the current will still be flowing directly from 7 to 8 (the path of least resistance) and not the resistor that's connected in parallel with it, yes a small amount of current will be going through that resistor, but not a significant amount. However if you cut the wire between 7 and 8 then current will start flowing through that resistor and you will get a voltage reading across it since it will now be in series with the other resistors. You can also test it by measuring amps on the wire going between 7 and 8. You put a resistor in parallel the amps aren't going to change a significant amount, and the amps going through the resistor will be close to 0, cut the wire between 7 and 8 then all the current will start going through that resistor and you will get an amp reading.
When an engine and transmission are bolted together, grounding the engine and grounding the transmission are doing the same thing since there is direct continuity between the two. If you are still able to test it I would like to see what happens when you test for resistance between the torque converter and the frame of the truck.
Patriot likes this.
00t444e is offline
post #39 of 55 Old 11-07-2019, 03:14 PM
Quoted: 145 Post(s)
Updated
Heavy_GD likes this.
Jack
post #40 of 55 Old 11-07-2019, 05:27 PM Thread Starter
Quoted: 413 Post(s)
Originally Posted by 00t444e View Post
The point of grounding the transmission and engine to the frame is so the electric will flow through the ground straps and not the transmission itself.
I still would still like to know where this supposed electricity flow through the transmission originates from (I won't argue that a slight potential exists IF you have a short in the transmission's internal harness - but I think it is a very low potential). You must have a (+) connection for electricity to flow to the (-) connection. Jack is showing that there is no connectivity between the frame, or the driveshaft for that matter, to the transmission.
All (+) electrical supply to the transmission controls has the circuit completed through the harness ground wires to the PCM, not through a transmission case ground (pages 29-1, 2, and 3 of Wiring Diagram Manual).
You can't have it both ways. Electricity is either intended to flow (return) through the transmission or it isn't. Clearly I am in the camp that it isn't intended to flow through the transmission (as are most of the people posting in this thread I assume).
With no practical source of a (+) connection, adding a ground strap (frame to the transmission body) will only increase the likelihood of some electrical flow through the transmission ... ESPECIALLY if the vehicle frame to block grounding is in bad shape.
It seems clear to me that this is why Ford doesn't want a second body unit grounded to the transmission, AND that is also why they didn't provide a ground between the transmission and frame from the factory.
Mark
No-start thread:
