06' F-350 Powerstroke crank but no start - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 Old 10-25-2019, 05:53 PM Thread Starter
Truck died pulling into fuel station yesterday. No abnormal issues prior to this. Hooked up Autoenginuity today & i have good FICM sync & voltage but am seeing only 210psi on the ICP during cranking, ICP pessure-desired is 1527psi, ICP voltage is .47, & IPR is reading 85%. Where should i look first to see where i'm losing oil pressure? No external leaks & base oil pressure is good. Truck has 81k miles no EGR delete & not bulletproofed. Added sinister coolant bypass filter & blue spring kit when i bought it 2 months ago.Any help is appreciated!
post #2 of 12 Old 10-25-2019, 06:04 PM
Quoted: 85 Post(s)
Could be an STC Fitting issue. Has it started again, since?
Sent from my SM-N950U using Tapatalk
mbsfield18 is offline
post #3 of 12 Old 10-25-2019, 06:08 PM
kcoyner's Avatar
Quoted: 216 Post(s)
Are you getting no start at all times? Hot and cold? Looks like an ICP issue based on AE.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #4 of 12 Old 10-25-2019, 06:11 PM
Quoted: 85 Post(s)
k
Good point
post #5 of 12 Old 10-28-2019, 10:53 AM Thread Starter
No start in all conditions
post #6 of 12 Old 10-28-2019, 10:55 AM Thread Starter
And has not started since. How do i upload pics on this forum? I can post AE values during cranking if it helps
post #7 of 12 Old 10-28-2019, 11:09 AM
You are going to have crawl under and take a look. Make sure the transfer case is still there.
leroy843 is offline
post #8 of 12 Old 10-28-2019, 11:14 AM
Quoted: 466 Post(s)
Garage
That 85% reading is a commanded position -- but just because the PCM is wanting more oil, does not mean the IPR valve is actually closing
I would suggest getting the IPR air test fitting, it's like $12 (+whip hose and ball valve from the hardware store)
There is a good chance you have blown the STC fitting -- time to upgrade to the fixed fitting if that is the case
bismic likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #9 of 12 Old 10-28-2019, 11:19 AM
jokester00's Avatar
Quoted: 502 Post(s)
Garage
Uhhhh...
I'm gonna give you the benefit of the doubt and say that you accidentally posted this in the wrong thread
-jokester
Quatermain likes this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #10 of 12 Old 10-28-2019, 02:45 PM Thread Starter
Okay, ordered the $10 fitting from amazon that'll be here in a day or two. Do i need to manually engage IPR using 12V while doing the air test? Thanks again to all of you helping me through this!
