How many miles on your 5R110? - Ford Powerstroke Diesel Forum
 8Likes
  • 2 Post By kcoyner
  • 1 Post By Integ46
  • 1 Post By letsmow10
  • 1 Post By mohead1
  • 2 Post By jokester00
  • 1 Post By Spirit
post #1 of 10 Old 10-18-2019, 05:55 PM Thread Starter
kcoyner's Avatar
Quoted: 202 Post(s)
I'm nearing 340K on mine. No sign of anything amiss. It's time for fluid and filter change but I always worry that I may stir up something. Fingers crossed and knocking on wood!
k
MrTommy and HeavyAssault like this.
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is online now
post #2 of 10 Old 10-18-2019, 06:04 PM
Integ46's Avatar
Quoted: 4 Post(s)
218,xxx on ole Betty Lou. No issues yet. Not knocking on wood. Iíll just leave it up to the Powerstroke Gods to choose its fate when the time comes and then pray to them for a decent rebuild. I should probably stop drinking now.
Sent from my iPhone using Tapatalk
kcoyner likes this.
Integ46 is offline
post #3 of 10 Old 10-18-2019, 06:07 PM
letsmow10's Avatar
Quoted: 117 Post(s)
Garage
Only about 205k on mine. I sure hope it makes it to 300+
Sent from my SM-G965U using Tapatalk
kcoyner likes this.
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes, KC Stage2
letsmow10 is offline
post #4 of 10 Old 10-18-2019, 07:38 PM
Quoted: 25 Post(s)
158k on the truck w that trans....all is well....i consistently tow with it around the Southeast, runs well
Sent from my SM-G960U using Tapatalk
kcoyner likes this.
mohead1 is offline
post #5 of 10 Old 10-19-2019, 06:43 AM
jokester00's Avatar
Quoted: 467 Post(s)
Garage
Just hit 150k on mine yesterday. I've only owned it for 39k of those
And if mine starts acting up in the next month, i'm blaming you LOL!
-jokester
bismic and kcoyner like this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #6 of 10 Old 10-19-2019, 06:52 AM
Brrrrrrr......cccccold
Quoted: 414 Post(s)
Just a hair over 171K....I will be changing the filters and fluids next weekend.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #7 of 10 Old 10-19-2019, 10:16 AM
Quoted: 8 Post(s)
I have 115k on my 2004drw. I had some work done to the tranny in 2005 at 35,000 miles due to the trans not engaging into reverse gear. Other than this, the tranny has proved solid. Here is what the dealer replaced at that time:
Cooler lines
trans filter kit
Main control valve body -- overhaul
solenoid valve -- shift
Internal wiring harness -- replace
kcoyner likes this.
Spirit is online now
post #8 of 10 Old 10-20-2019, 03:17 AM
7.3lf550's Avatar
Quoted: 73 Post(s)
240k or so in my excursion. Trying to wreck it. so i can have a reason to overhaul/upgrade. 175/30s w/ kc stage 2 and it still wont let go. Chirps the tires in third still.
7.3lf550 is offline
post #9 of 10 Old Today, 02:40 PM
My '07 just crapped out at 194k. Full of metal shavings.
Harley_SD is offline
post #10 of 10 Old Today, 05:40 PM Thread Starter
kcoyner's Avatar
Quoted: 202 Post(s)
Man that sucks! I'll be watching to see how it works out for you.
k
