8500lb+ GVWR Scan Tool/Code Reader - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By frozenpepper70
post #1 of 9 Old 09-26-2019, 04:45 PM Thread Starter
Hello. I am new to the forum...... I currently own a 2006 Ford Superduty F-350 4X4 Dually.
I am looking for an 8500lb+ GVWR automotive scan tool/code reader that is bi-directional and capable of reading engine codes, ABS, SRS and factory embedded information on trucks such as Ford Superduty Powerstroke F-250's, F-350's, Chevrolet 2500"s and 3500's, etc. I have used Innova scan tools on cars in the past with success, however an engineer at Innova advised me that their scanners are not designed to read any vehicle with a GVWR over 8500lbs and that they do not offer one that does. Does anyone know of, and have personal experience with a scanner/reader in existence that doesn't cost a fortune? Thanks for your help.
Powerstroke1212 is offline
post #2 of 9 Old 09-26-2019, 05:09 PM
UR2EZ's Avatar
Quoted: 64 Post(s)
Howdy and welcome from Texas!
As for the scanner info, I'm sure someone on here has the knowledge you seek. Great place, great people, and tons of knowledge/experience. Good luck!
Sent from my SM-G975U using Tapatalk
UR2EZ is offline
The Following 2 Users Say Thank You to UR2EZ For This Useful Post:
Powerstroke1212 (10-06-2019)
post #3 of 9 Old 09-27-2019, 07:27 PM
frozenpepper70's Avatar
Quoted: 7 Post(s)
Garage
I'm pretty sure AutoEnginuity will read all the niche codes these trucks can throw. As for basic codes, any auto scanner will read them. I use a Bluetooth scanner and an app on my cell phone to read codes and data from my F350. Good luck
HeavyAssault and jokester00 like this.
603
frozenpepper70 is offline
The Following 2 Users Say Thank You to frozenpepper70 For This Useful Post:
post #4 of 9 Old 09-29-2019, 10:45 PM
Quoted: 15 Post(s)
[email protected] is a good resource and sells the AE Ford bundle on his site.
2005 F550 Camper KDD Stage 2 Long Block, PSP Lifters, WDI 155/30, ATS Coolant Recirc, BPD EGR Cooler, Oil Cooler, & Water Pump, Odawgs S2.0 Intake, BD Exhaust Manifolds, No-Limit CAI, Catch Can, & CAC, KC Stage 1.5 Turbo, Driven Diesel Regulated Return & Dual Bosch Fuel System, MBRP 4" Turbo Back Exhaust & HD Up Pipes, Mishimoto Thermostat & Hoses, IPR High-Flow Coolant Filter, PSP Degas Tank, 7.3 Fan Clutch, DC Power 270XP Alternator, Fluidampr, Insight CTS2, Titan Tank, Bean Sump, SCT X4
RideFalkor is offline
The Following 2 Users Say Thank You to RideFalkor For This Useful Post:
post #5 of 9 Old 09-30-2019, 06:14 AM
Quoted: 395 Post(s)
It only reads parameters and codes, but ForScan Lite on a smartphone will read all of the modules. The download and the ELM327 adapter combined cost around $40. The full version of ForScan on a laptop will do a whole lot more.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
The Following 2 Users Say Thank You to bismic For This Useful Post:
post #6 of 9 Old 10-01-2019, 06:22 AM
G8orFord's Avatar
Quoted: 2552 Post(s)
Garage
Forscan is Ford (and some Mazdas) specific. You can get AE for multiple brands, but I'm not sure on the pricing for each.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
The Following 2 Users Say Thank You to G8orFord For This Useful Post:
post #7 of 9 Old 10-01-2019, 09:23 AM
Quoted: 6 Post(s)
For what your looking for AE maybe your best bet. With them you can get bundles for all auto manufacturers.
Sent from my iPhone using Tapatalk
2004 F-350 Lariat, SRW long bed 4x4 FX4. coolant filter and pyro are the only mods.
hoodshauler is offline
The Following User Says Thank You to hoodshauler For This Useful Post:
post #8 of 9 Old 10-01-2019, 10:17 AM
wiredgeorge's Avatar
Quoted: 25 Post(s)
I use and SXT X4 tuner to pull and delete codes but it didn't catch the Ford code for too great delta between coolant and oil temps that was causing my truck to throw a wrench engine light. Forscan is cheap and will catch these. I am not sure you will find one scanner that fits all your criteria. I have the 50hp tow tune on my truck mainly because of an EGR delete. I bought one that didn't have the latest firmware and could still turn the CEL off.
2006 Ford F-350 6.0L Auto CC 4WD LB
2002 Keystone Cougar 278EFS
2006 GL1800 Roadsmith trike
Mico TX
wiredgeorge is offline
The Following User Says Thank You to wiredgeorge For This Useful Post:
post #9 of 9 Old 10-06-2019, 05:54 PM Thread Starter
Thank you all for the information.
I will look at the scanners and tuners mentioned. I have family that are in the automotive business and all of the scanners that they are using are $5,000 to $20,000 units with annual software updates running $1,000+ per year which both costs are obviously out of the question for me.
