Rotella T6 5w40 or 15w40 in 6.0 - Ford Powerstroke Diesel Forum
 16Likes
post #1 of 27 Old 09-23-2019, 07:51 AM Thread Starter
Hblick48's Avatar
Quoted: 15 Post(s)
I purchased my 6.0 three years ago. On my first oil change, I switched to Rotella T6 5w40. Somewhere I read a Ford Bulletin saying that when switching to a synthetic, 5w40 was an approved oil for use in the 6.0. I've put over 35,000 miles on it since the oil type change.
Two oil changes ago I had an oil analysis done that said the engine was in great shape. A few months ago, I had a Ford Master Mechanic Bulletproof it. When he had the heads off to stud, he could still see the cross-hatching in the cylinder bores, indicating very minimal wear.
Now that Rotella is also available in 15w40, should I switch to it next oil change, or stay with 5w40?
HeavyAssault and pphelps like this.
Hblick48 is offline
post #2 of 27 Old 09-23-2019, 08:17 AM
JustinOOO9's Avatar
Quoted: 1548 Post(s)
Garage
Feedback Score: 3 reviews
Personally both are great oils. If you see cold (not relative cold) but like below under 30 degrees for a few months of the year stick with the 5w-40. The truck will have smoother cold weather operation. I only switched to the newer t6 15w-40 because my old 7.3l was burning the 5w-40 more than I liked. Im back to normal with the newer weight being just a bit thicker. (not sure how much but its reduced my oil consumption back to normal etc).
HeavyAssault and john galt like this.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #3 of 27 Old 09-23-2019, 08:39 AM
ZMANN's Avatar
Quoted: 3899 Post(s)
I live in Arizona i have always run the 5-40 mine does not lose any oil between changes and startups are always easy
john galt likes this.
6.0 flush pdf
ZMANN is offline
post #4 of 27 Old 09-23-2019, 11:10 AM Thread Starter
Hblick48's Avatar
Quoted: 15 Post(s)
Mine doesn't burn any oil, never have to add oil between changes with the 5w-40. Just turned 150,000 miles.
Hblick48 is offline
post #5 of 27 Old 09-23-2019, 11:25 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 797 Post(s)
Sounds like you know what oil to keep using.
john galt and jokester00 like this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #6 of 27 Old 09-23-2019, 01:25 PM
Quoted: 20 Post(s)
I've run the T6 5W40 since it came out, and I love it. Great oil. Really quieted down my motor.
Sent from my SM-N950U using Tapatalk
mbsfield18 is offline
post #7 of 27 Old 09-23-2019, 01:58 PM
ChrisSki's Avatar
Quoted: 552 Post(s)
I notice I see T6 5W40 and T6 15W40 available locally. My guess is the T6 5W40 is being phased out. I see the 5W40 less and the 15W40 more. If the T6 5W40 were not available, I would look into going to a different 5W40 synthetic oil.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
post #8 of 27 Old 09-23-2019, 02:15 PM
Quoted: 20 Post(s)
I've actually seen it the other way around. As far as the 5W40 goes, it was introduced to provide better fuel mileage.
post #9 of 27 Old 09-23-2019, 04:36 PM
N.S.D.Q.
Quoted: 797 Post(s)
Well looking at the Rotella site, they now have 5w40 AND 15w40 full synthetic oil. Interesting, I didn't notice that before.
post #10 of 27 Old 09-23-2019, 05:16 PM
Quoted: 20 Post(s)
When they first reformulated the T6 they only released the 15W40. Then, they slowly started rolling out the 5W40.
