Runs great then Dyson after 15 to 20 min - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 13 Old 09-21-2019, 02:26 PM Thread Starter
Jason Patterson's Avatar
Runs great then dyes after 15 to 20 min.
Hello all im a new member hope someone can help.😀
I have a 2005 6.0 was driveing down the road it Acted like it was running out of fuel then dyed.it would not restart had to get it towed home. I replaced the 2 fuel filters and replaced the cam sensor and the crank sensor then the ficum.the mechanic said he was 75% the ficum it was not then the other parts did not help. I have torque pro I will post screen shot.now it sits in my drive way can't drive it because I don't know what's wrong with it allready spent close to 700$ .I have video of it sputtering can't upload it.
ID:	723387   Click image for larger version
ID:	723389   Click image for larger version
Jason Patterson is offline
post #2 of 13 Old 09-21-2019, 03:04 PM
jokester00's Avatar
Quoted: 465 Post(s)
Garage
Any codes? Do you have a fuel pressure gauge?
As for the video, upload it to youtube and then post the link here.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 13 Old 09-21-2019, 07:22 PM Thread Starter
72 psi for fuel gauge.
Not throwing any codes.
post #4 of 13 Old 09-21-2019, 07:28 PM Thread Starter
post #5 of 13 Old 09-22-2019, 11:48 AM
jokester00's Avatar
Quoted: 465 Post(s)
Garage
Did this just start happening out of the blue? Have you had any work done recently? Are you getting any smoke out the tailpipe while it sputters? When's the last time you put fuel in it?
For giggles, i'd unplug the ICP sensor to see if that makes a difference.
-jokester
Edge EAS EGT probe
post #6 of 13 Old 09-22-2019, 06:31 PM
ChrisSki's Avatar
Quoted: 554 Post(s)
Iím curious as to why the mechanic said FICM. Seems a rock solid 48 or 48.5 volts and thatís what Iíd check.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #7 of 13 Old 09-22-2019, 07:35 PM
jokester00's Avatar
Quoted: 465 Post(s)
Garage
I wonder if he had codes prior to the FICM being changed and the shop cleared them...
-jokester
ChrisSki likes this.
Edge EAS EGT probe
post #8 of 13 Old 09-23-2019, 03:53 AM
Quoted: 327 Post(s)
I think the FICM has already been replaced and those readings are after the replacement.
The torque app isn't the most thorough code reader. ForScan is better for that. You really need a thorough scan for codes.
What oil are you running and how long (how many miles) has it been in there? Is the oil level good?
btw - it is FICM (Fuel Injection Control Module) not FICUM.
Patriot likes this.
bismic is offline
post #9 of 13 Old 09-24-2019, 05:57 AM Thread Starter
I unplugged the icp no change.no work has been done. No smoke except when cold then none.
post #10 of 13 Old 09-24-2019, 05:58 AM Thread Starter
Oil levels look good.
