'03 COOLING ISSUES - Ford Powerstroke Diesel Forum
 5Likes
  • 1 Post By junior125
  • 1 Post By R&Rpowerstroke
  • 1 Post By Pip7899
  • 1 Post By Kabledogg
  • 1 Post By bismic
post #1 of 10 Old 09-17-2019, 08:02 AM Thread Starter
dvlishdan's Avatar
Question '03 COOLING ISSUES
My 6.0 is running around 210 unloaded and will spike up to 250 wile driving. Ok some back ground..... About a month ago i was towing my 5er home from Nashville when the temp spiked up to 260. Pulled to the side and found my degas bottle had split. Finally made it home and replaced the bottle and the temps were still around 250. after taking a harder look i noticed the Fan wires were shredded. I then replaced the fan with a mechanical fan, new thermostat and fresh coolant. last week i took a 1200 mile trip pulling the camper and couldn't get over 70 mph before the temp would spike up......... all help and suggestions is appreciated.
dvlishdan is offline
post #2 of 10 Old 09-17-2019, 08:08 AM
Fummins Mod
junior125's Avatar
Quoted: 2194 Post(s)
Garage
possible the water pump impeller is spinning on the shaft, are you puking coolant or loosing coolant?
jokester00 likes this.
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #3 of 10 Old 09-17-2019, 09:07 AM Thread Starter
dvlishdan's Avatar
yes but not a lot. i just assumed it was when the temps pegged out.
post #4 of 10 Old 09-17-2019, 04:22 PM
R&Rpowerstroke's Avatar
Quoted: 101 Post(s)
Garage
Check your coolant pressure to see if you blew a head gasket. I was constantly over 220-230 when pulling a light load and was studded and deleted at the time, but checked coolant pressure and sure enough had to redo gaskets. Went with UCF heads, arp 625's and zero issues pulling heavy loads up grades. If it is just a water pump Dieselsite makes a nice one, if you think it is just thermostat get an oem.
bismic likes this.
R&Rpowerstroke is offline
The Following 2 Users Say Thank You to R&Rpowerstroke For This Useful Post:
dvlishdan (09-17-2019)
post #5 of 10 Old 09-17-2019, 05:59 PM
Most of the newer thermostats fail open these days. But I do agree on the water pump. If you are seeing anything visible leaking address it first. Would suck to keep testing while you know it’s leaking somewhere and blow the head gaskets. Especially if they are actually still on at this time.
dvlishdan likes this.
Pip7899 is offline
The Following 2 Users Say Thank You to Pip7899 For This Useful Post:
dvlishdan (09-19-2019)
post #6 of 10 Old 09-20-2019, 05:47 AM
Quoted: 6 Post(s)
What is the build date on your truck? How many miles? The early 03 had a smaller water pump 90 mm and will cause a leak if you bolt to updated cover. See bold below:
2004 Model Year Changes:
The water pump impeller diameter has increased in size to 100 mm from 90 mm. Note: Both water pumps have the same bolt pattern, but a different sealing area. As a result, the smaller water pump has the physical ability to be installed into an updated front cover. If this is done, a coolant leak and over heating of the engine may result.
Make sure you pay attention to this if you are going to replace pump.
bismic likes this.
Kabledogg is offline
post #7 of 10 Old 09-20-2019, 06:15 AM Thread Starter
dvlishdan's Avatar
The build date on my truck is 12/02 the truck has 237K miles but i had the water pump replaced with a Motorcraft pump about 6 years ago. This time i am going back with metal impeller.
post #8 of 10 Old 09-20-2019, 09:25 AM
Quoted: 327 Post(s)
I hate to say it, but head gasket issues are likely. If not a root cause, then a consequence from the high temps.
R&Rpowerstroke likes this.
bismic is offline
post #9 of 10 Old 09-20-2019, 10:00 AM
Quoted: 6 Post(s)
You may want to watch this, it is a great way to test for head gaskets: youtube.com/watch?v=wis6BFvI7zY at least rule them out.
Parts to build test gauge are not that much, find hardware store and purchase everything in one spot usually. I ordered this as I was not in a hurry: ebay.com/itm/1-8-NPT-Air-Compressor-Lower-Mount-Pressure-Gauge-0-100-PSI-Side-WOG-2-Face-/273650162866?hash=item3fb6d21cb2
You can reuse the gauge for other things like testing fuel pressure with the correct adapters. I wish you luck and hope it is not HG's.
post #10 of 10 Old 09-22-2019, 05:57 AM Thread Starter
dvlishdan's Avatar
thanks i have done the head gasket check and it is not reading any excessive pressure. going to change the water pump and thermostat this week and see what happens
