6.0 Upgraded EGR kit for sell - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ChrisSki
post #1 of 8 Old 09-16-2019, 11:51 AM Thread Starter
Quoted: 35 Post(s)
EGR Cooler-XL SINISTER DIESEL for 04 6.0 Ford . Condition is Brand New.
This item is 50-State Legal - CARB EO# D-721
Sinister Diesel has reinvented the Exhaust Gas Recirculation (EGR) cooler with this great new model for the 6.0L Powerstroke with the same fit as the stock unit from Ford. This EGR cooler kit comes with a new square-style EGR cooler and an installation kit that includes the water outlet connector hose, intake gaskets, o-ring kit, and turbo bolts.
One of the major concerns with the factory EGR Cooler is that when the internal brazing cracks, coolant is sucked into the intake manifold. From the manifold it enters the combustion chamber which usually results in a blown head gasket or hydro-locked motor and costly repair bills for thousands of dollars!
If you're tired of clogs and the possibility of a catastrophic failure with the stock 6.0 Powerstroke EGR cooler, or if you just want to prevent future headaches from unnecessary maintenance, replace it with one of Sinister Diesel's upgraded EGR cooler. Instead of the narrow internal cooling fins with brazed connections, we assemble each 6.0 Powerstroke EGR cooler using high-flow stainless steel tubing with quality TIG welds for reliability that the stock units can't match. And because of the factory-matching fit, installation is easy. You won't even have to remove the intake manifold!
The Sinister Diesel 6.0 Powerstroke EGR cooler comes backed by the legendary Sinister Lifetime Warranty and has been extensively tested at our California headquarters to be 100% legal in all 50 States with a CARB EO# D-721 certification. Additionally, we guarantee that this upgraded EGR cooler it will work with any performance chip or tuner on the market. It will even work flawlessly with the stock Ford Powerstroke ECM without need for any modification. Installation is a simple, direct, drop in replacement on any 2004, 2005, 2006, or 2007 Ford F-250/F-350 Super Duty or Ford Excursion with a 6.0L Powerstroke diesel engine.
Features:
Stainless Steel Construction
Fully TIG Welded and Pressure Tested
Improved exhaust gas flow
Kit Includes:
Sinister Diesel 6.0 Powerstroke EGR Cooler (Square)
Intake Gasket Kit
Water Outlet Connection Hose
Turbo Bolt
O-ring kit
Would like to get $380 + shipping OBO
Sent from my SM-N950U using Tapatalk
mbsfield18 is offline
post #2 of 8 Old 09-16-2019, 01:41 PM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 322 Post(s)
there is an actual place to sell items on the forum
this is the 6.0 discussion area
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #3 of 8 Old 09-16-2019, 01:58 PM Thread Starter
Quoted: 35 Post(s)
Where is it? I obviously don't know about it.
post #4 of 8 Old 09-16-2019, 02:03 PM
Hate stupid people
Quoted: 322 Post(s)
down past where you found this specific section there's a classifieds
click Forums
scroll 3/4 of the way down
click "For Sale & Wanted Items"
click Performance & Drivetrain parts
new thread
EFI Live tuned 6.7
The Following User Says Thank You to CloverLeafFarm For This Useful Post:
mbsfield18 (09-16-2019)
post #5 of 8 Old 09-16-2019, 02:11 PM
ChrisSki's Avatar
Quoted: 554 Post(s)
https://www.powerstroke.org/forum/sa...-members-only/
There's probably 100 sections or rooms in this forum.
partyman97_3 likes this.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
The Following User Says Thank You to ChrisSki For This Useful Post:
post #6 of 8 Old 09-16-2019, 06:27 PM Thread Starter
Quoted: 35 Post(s)
Your link didn't work
post #7 of 8 Old 09-17-2019, 03:09 AM
ChrisSki's Avatar
Quoted: 554 Post(s)
I hope a moderator will help. With 79 posts I think youd be able to see that section. Its members only, and certain things are limited by number of posts, perhaps that is also.
Ravelco
Good 6.0 Reading:
ChrisSki is offline
post #8 of 8 Old 09-17-2019, 03:32 AM Thread Starter
Quoted: 35 Post(s)
I'm on my phone using the Tapatalk app and if I go back where I found this, there are 4000 posts.
