Weight of the truck for a lift - Ford Powerstroke Diesel Forum
 12Likes
post #1 of 20 Old 09-12-2019, 04:42 AM Thread Starter
Quoted: 8 Post(s)
Garage
Hi All. I've been quiet around here as I've been pretty busy at home. I've been building a new shop. Something I've waited all my life to do. I'm in the process of picking out a 2 post lift. I'm probably getting it from Greg Smith Equipment (atlas brand lift) but there's some confusion what one I need to lift the truck. It's an '03 6.0 4x4 short bed with the 4 door cab. I've been told a 9k lift will be fine BUT the lift people are trying to put me into a 10k which is right about $1,000.00 more cost. That's a big jump if I don't NEED to.
I guess the 9K lift has a per arm lift capacity of 2,250lbs and the 10K has a per arm capacity of 2,500lbs So what does the front of our beloved rigs weigh? I've been having a hell of a time finding that info since last night. And then it hit me ...."hey dummy ask the forum".. so here I am hoping someone here will know before I have to go beg the guys at the scrap yard to let me put the truck on the scales.
Ceiling height isn't an issue. I built the shop at 30x40ft with 14ft ceilings. Concrete is 6 inches in the bay I'm putting the lift and 5 the other 2. So I'm good there.
ID:	723029   Click image for larger version
flared65 is offline
post #2 of 20 Old 09-12-2019, 04:59 AM
G8orFord's Avatar
Quoted: 2517 Post(s)
Garage
I'd go at least 10k for safety purposes. An extra grand isn't that much when your life may depend on it. We have an 8k lift, but I won't get under my 7,750 lb. 6.0 on it. I have used it to rotate the tires. I also use tall support stands on just about everything I put on the lift as an extra safety precaution. If we ever replace the one we have, I'll go 12k.
bismic, junior125 and mbsfield18 like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #3 of 20 Old 09-12-2019, 06:17 AM Thread Starter
Quoted: 8 Post(s)
Garage
I totally understand what you're saying but the lifts are tested higher than what they are rated for. I just don't know what the weight of the truck is on each end. I know total is under 9k so capacity wise total I am fine. I know a few people who lift their 250's with 9k lifts. It's a tough one since I am know the truck should have a GVW of what a tick over 6,000lbs. with the backrack i have on there maybe what 6,000lbs give or take a little. So well under the 9K total. All the other stuff I will work on is much lighter.. My jeep wrangler , the mustang.. etc. the 250 is the biggest thing I own.
flared65 is offline
post #4 of 20 Old 09-12-2019, 06:22 AM
ChrisSki's Avatar
Quoted: 550 Post(s)
The Air Force Base has a place where we can rent a stall and they have 4 post lifts where we can do our own work, but since the lifts were installed 20 years ago, they don't let me get the pick up on it. It must be well in excess of a 10k lift.
Also used to use a tire scale to figure out load and balance of vehicles prior to putting them on an aircraft. If I still had access to a tire scale, I'd post the front axle weight.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 20 Old 09-12-2019, 06:26 AM
Quoted: 25 Post(s)
Nice shop....wanna expand mine w a lift too....anyway, with that truck only and mothing larger you will be ok. They do under-rate the lifts. I would still contact Greg Smith to talk to a specialist, NOT just the sales person. Make very sure of the over rate per the manufacture. Or call other lift makers and discuss for piece of mind and safety
Sent from my SM-G900V using Tapatalk
mohead1 is online now
post #6 of 20 Old 09-12-2019, 06:31 AM Thread Starter
Quoted: 8 Post(s)
Garage
I did talk to them yesterday but possibly just a sales person though. He was asking me how heavy the front of the truck was. I went a little over budget so far because I wasn't planning on putting PEX tube into the slab to do radiant floor heat at some point. So that cost me a little more than I planned. I'll try calling them again today.
I guess also in looking at the Atlas models the 9K uses a single cylinder with a roller chain to lift (more moving parts) where the 10K uses 2 cylinders to lift. Less moving parts for service down the road and the 10K would be a little more forgiving on the placement of the truck on the lift. UGG decisions... decisions....
flared65 is offline
post #7 of 20 Old 09-12-2019, 07:09 AM
Old School
Chris's Avatar
Quoted: 39 Post(s)
Garage
I have an 06 crew cab short bed 4WD and the last time I had it on the scales it was close to 8k pounds. Why not just drive down to your local scales or dump and weigh the truck so you know for sure?
mohead1 and partyman97_3 like this.
2006 Ford F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, South Bend Dual Disc Clutch SFDD3250-6.0, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front and Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit, Morimoto LED Fog Lights, Bilstein 5100s
Fast, cheap, reliable...pick two.
Chris is offline
post #8 of 20 Old 09-12-2019, 08:02 AM Thread Starter
Quoted: 8 Post(s)
Garage
Originally Posted by Chris View Post
I have an 06 crew cab short bed 4WD and the last time I had it on the scales it was close to 8k pounds. Why not just drive down to your local scales or dump and weight the truck so you know for sure?
Google keeps coming up with 03 crew cab 6.0 4x4 with automatic curb weight at 6,364lbs. Odd that yours would show close to 8k. Nothing on this list for '03 is higher than 6,364lbs.
flared65 is offline
post #9 of 20 Old 09-12-2019, 08:18 AM
voodooridr's Avatar
Quoted: 951 Post(s)
My '04 CCSB, 4" lift with 35's and a bed topper came across the scales at the dump at 8226 pounds
Sent from my SM-G960U using Tapatalk
mohead1 likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #10 of 20 Old 09-12-2019, 08:46 AM
Quoted: 16 Post(s)
Aftermarket wheels, tires, hitches, bumpers, racks, toppers..........they all add weight. It's best to hit the scales.
Sent from my LG-LS993 using Tapatalk
5J's is offline
