Steering issue: need some help - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 17 Old 09-08-2019, 06:30 AM
Quoted: 327 Post(s)
Originally Posted by crankn101 View Post
I have been having some major issues with my steering and most was due to laziness and procrastination on my part. Now Im trying to get it all straightened out and Im still struggling.
New OE draglink and alignment
Flushed 1 gallon of Merc LV through the system 2 separate times (should I switch out to Merc5?)
I have this interment problem while just cruising down the road trying to maintain my lane. The steering wheel will feel like it hits a "wall" and then pushes through and sends me towards the other lane then I correct it and does the same thing the other way.
It can act pretty normal for miles at a time then act up for miles at a time.
Any ideas?
Im going to rev it up to 2,000 and check the steering side to side again and see if its smooth.
You are using LV for the power steering? I know some folks that have done it, but I wouldn't use it there.
bismic is offline
post #12 of 17 Old 09-08-2019, 06:48 AM
Quoted: 327 Post(s)
Here are the spec sheets. LV is quite a bit thinner.
bismic is offline
post #13 of 17 Old 09-10-2019, 09:49 AM Thread Starter
Quoted: 11 Post(s)
Can you guys tell me with which seals I will be needing? I remember when I changed out the wheel bearing there was an issue of some kind. Maybe two different seals being "updated" with only one seal? The truck is an 06'
crankn101 is offline
post #14 of 17 Old 09-11-2019, 05:12 PM
Quoted: 12 Post(s)
Garage
If you have vacuum operated hubs you should replace I think 3 seals, they are the wheel bearing o-ring, the inner wheel bearing seal(should have installation tool for this seal), and the outer axle seal at the end of the tube-may have updated the design from original
Also just FYI check you ball joints really good. You are going to be right there, I usually change the ball joints anyways because of the cost of the seals and time. And if I am doing the ball joints it automatically gets a new axle joint. Just my preference cause I only want to do it once.
If your not in a big hurry check ebay for a kit that includes everything, there is a company thats sells the kit pretty much all spicer parts and reasonable. I have used them a few times and have not been disappointed yet. FWIW
Teazr is offline
post #15 of 17 Old 09-11-2019, 05:22 PM
Quoted: 361 Post(s)
Garage
You can mod a couple pieces of pvc pipe to use as the install drivers for that large seal -- and some denatured alcohol for lube on the outside of the seal
Several vids on the tube to see how to remove the axle -- squirt some of the aforementioned lube on the old seal and a large prybar will pop the seal and axle right out
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #16 of 17 Old 09-11-2019, 05:38 PM
Quoted: 12 Post(s)
Garage
I am sure you can make a tool that works but if you screw up the seal its probably more expensive buying another seal then if you bought the right tool on amazon for 50-60 bucks and it makes great paper weight LOL
And what is your time worth going to get the pipe you need and then making a tool?
Just my way of thinking
Teazr is offline
post #17 of 17 Old 09-11-2019, 05:53 PM
Quoted: 361 Post(s)
Garage
Pretty much just a hand press into the bore -- the tool just helps to keep the seal square
Each to their own I suppose, tho thinking one must own a special use tool, for one use is a waste for most homeowner/mechanics
denatured alcohol is useful to lube the rubber coated seal surface, then evaporate to allow it to stick in place -- never use oil on the seal surfaces, unless you want the seal to move where ever it wants later
General note:
Hydro is offline
