Crazy Smoke and Oil Out of the Exhaust - Page 3 - Ford Powerstroke Diesel Forum
 5Likes
post #21 of 25 Old 09-11-2019, 06:09 PM
Quoted: 359 Post(s)
Garage
Late to the party: Did the smoke happen after you took the injectors apart?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #22 of 25 Old 09-11-2019, 06:33 PM Thread Starter
Quoted: 5 Post(s)
Yes it did
jlang95 is offline
post #23 of 25 Old 09-11-2019, 06:33 PM
Quoted: 359 Post(s)
Garage
Originally Posted by jlang95 View Post
So update, I pulled the injectors and separated the upper and lower bodies. The fuel spring on the lower body of the injector is broke on 7 of the injectors. And I pulled the turbo and the outlet and the down pipe are covered in thick oily residue.
My guess is that the new orings on the outside of the injectors uncovered an ongoing problem -- the internal body oring was leaking and the pintle springs was busted
The upper external oring since it was new and sealing better pushed the oil that was previously leaking past, and into the crankcase -- down into the fuel rail, and into the combustion
The broken pintle springs were causing the injector tip to have a poor/no spray pattern -- incomplete combustion happened -- the ECU would have basically shut the fuel off to keep engine speed and you were running on engine oil -- so lots of smoke and snot
Those lower springs pre load the injector pintle to about 3900psi -- without them working as they are supposed to, the nozzle just squirts a stream
Seven broken in one engine seems to me to be odd, maybe they were just old
General note:
Hydro is offline
post #24 of 25 Old 09-11-2019, 06:45 PM
Quoted: 359 Post(s)
Garage
Vid could have been better, but shows the part order of the lower injector assembly
https://www.youtube.com/watch?time_c...&v=6uSCa9_1n4I
General note:
Hydro is offline
post #25 of 25 Old 09-11-2019, 06:50 PM Thread Starter
Quoted: 5 Post(s)
I was surprised there were that many broken as well. But oh well. It’ll be down for a little and then it’ll be back up in running with some new injectors, turbo, intake, and HPOP!
jlang95 is offline
