Exterior light circuit schematic? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 14 Old 08-26-2019, 03:22 PM Thread Starter
Quoted: 59 Post(s)
I posted about this in the Electronics section, but figure there's more eyes here.
tl;dr - My exterior light 15a fuse immediately blows when I flip the headlights on. I've removed all the bulbs all the way around, still blows - so I'm 99% certain it's a wire rubbed through somewhere.
Hoping someone has the diagram so I can start tracing the wiring... ?
Thanks!
Doward is offline
post #2 of 14 Old 08-26-2019, 05:07 PM
Quoted: 358 Post(s)
Garage
Have you checked at the trailer plug for loose wires?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 14 Old 08-26-2019, 05:28 PM Thread Starter
Quoted: 59 Post(s)
Key off, headlight switch off, no fuse in the #17 spot.
Ran a continuity test to ground - only the bottom left of the 7 pin and single 'exposed' of the 4 pin beeped at me. That leads me to believe no shorts to ground in the wiring between the fuse and the receptacle for the trailer wiring.
Doward is offline
post #4 of 14 Old 08-26-2019, 05:49 PM
Quoted: 358 Post(s)
Garage
Possibly the wiring in the steering column that runs to the headlight "dimmer" switch? -- the transmission shifter mechanism and the wiring in the column can get together and cause all kinds of fun problems -- could disconnect the column harness and see if that locates the problem
General note:
Hydro is offline
post #5 of 14 Old 08-27-2019, 04:12 PM Thread Starter
Quoted: 59 Post(s)
I'll check out the wiring in the steering column, too.
Nobody has the schematic, though? It'd be extremely helpful to know where the fuse sits in the circuit, for instance, so I can test both sides of the fuse (and hopefully narrow down where my bad wire is!)
Doward is offline
post #6 of 14 Old 08-27-2019, 04:26 PM
Got Dirt?'s Avatar
Quoted: 177 Post(s)
Garage
This help?
File Type: pdf Wiring Diagram - 2005 Powerstroke 6L - F-Series - Single Alt - Full.pdf (3.49 MB, 10 views)
People are like dirt. They can either nourish you and help you grow as a person or they can stunt your growth and make you wilt and die.
Plato
2006 Super Duty F-250 Lariat CCSB: Edge CTS Insight w/ EGT & Fuel Press. - BPD FICM - Sinister Diesel Coolant Filter - ProComp 20" wheels - Toyo M/T 35's - ReadyLift w/ Bilstein 5100's - 4" MagnaFlow Exhaust - '08 Transmission Pan and Filter..... and a Partridge in a Pear Tree!:wink[3]:
Got Dirt? is offline
post #7 of 14 Old 08-27-2019, 04:46 PM
Got Dirt?'s Avatar
Quoted: 177 Post(s)
Garage
These might be better.
Hydro likes this.
Plato
post #8 of 14 Old 08-29-2019, 04:31 PM Thread Starter
Quoted: 59 Post(s)
Appreciate it, but it's hard for me to read 'em. I just bought the stupid electrical wiring manual, so I'll be able to track down any future electrical issues with ease
Got Dirt? likes this.
Doward is offline
post #9 of 14 Old 09-15-2019, 06:38 PM Thread Starter
Quoted: 59 Post(s)
Update on this!
Wiring book came in. What a freaking difference that made
Ruled out any issues pre-headlight switch. It's the brown wire. Disconnected *everything* external, checked for continuity between the brown and black wires on the mirrors - confirmed I have a short in the wiring.
Tone generator showed up today, but I was in the middle of rewiring my FIL's old trailer, so didn't get a chance to start tracing today.
Hopefully I'll be able to find out more this week, though!
Doward is offline
post #10 of 14 Old 09-20-2019, 07:06 AM Thread Starter
Quoted: 59 Post(s)
Took the day off of work for some appointments, trying to do more diagnostics.
I've disconnected every single connector I've been able to locate - still have short to ground on the exterior lighting power wire (brown). Got my hands on a tone generator, and it turns out since I'm shorting to ground, trying to trace the wire in the dash is a lost cost - every ground (including the metal frame) is naturally causing the tone locator to light up!
I've basically resigned myself to having to take the entire dash out at this point. I DO have an '08 dash I was intending to swap - maybe I'll just start on that. At least after all the effort I'll have something a little more worthwhile than 'the exterior lights work again'
Doward is offline
