Man, the smoke - Page 5 - Ford Powerstroke Diesel Forum
 51Likes
post #41 of 43 Old 08-28-2019, 06:54 PM
Originally Posted by bismic View Post
I wouldn't count on the rotor NOT being warped.
I definitely wouldn't re-use the caliper.
+1!!! Replace both sides at the same time. If one goes, the other is probably not far behind....
MrTackett is offline
post #42 of 43 Old 08-29-2019, 02:55 AM
Old School
Chris's Avatar
Quoted: 42 Post(s)
Garage
So did the guy fix his brakes or no? lol
Hydro likes this.
2006 Ford F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, South Bend Dual Disc Clutch SFDD3250-6.0, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front and Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit, Morimoto LED Fog Lights, Bilstein 5100s
Fast, cheap, reliable...pick two.
Chris is offline
post #43 of 43 Old 09-04-2019, 08:14 AM Thread Starter
twood71's Avatar
Quoted: 66 Post(s)
I mainly was trying to figure out what was bad.
It Wasn't the brake line.
The caliper top cylinder was stuck out. Would not retract.
My son reminded me 2 days prior I had to hit my brakes pretty hard, may have been the spiral down hill moment for the caliper?
I have a mental issue and it can get pretty bad, I like to find out what went wrong before I replace parts regardless if it's the part itself or many parts just to be safe.
For zsargent, piece of mind the truck had all new hubs and all new brakes done back in March, new tires as well. I do rotate tires, but the Dually is a bit misleading
jokester00 likes this.
twood71 is offline
