Bleeding the hydroboost system? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 17 Unread 08-22-2019, 01:34 PM Thread Starter
Quoted: 11 Post(s)
Is this the correct method?
Jack the truck off the ground
While the truck isnt running...
turn lock to lock 5 times
pump brakes 3 times
Repeat 40 times?
crankn101 is offline
post #2 of 17 Unread 08-22-2019, 03:01 PM
frozenpepper70's Avatar
Quoted: 7 Post(s)
Garage
That is correct. It works, but yes, you literally need to pump it 40+ times. Initially I skimped out and paid for it - loads of air in my lines.
If your pedal is still spongy or almost has a springy feeling, you need to do it more.
Sent from my Pixel using Tapatalk
frozenpepper70 is offline
post #3 of 17 Unread 08-22-2019, 03:16 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
No that is NOT how it’s accomplished
I’m giving another two bits here.
Pull return hose off the hydro boost and get 6’ of 3/8” line. Connect it to boost and drop it ina 5 gal bucket.
Hope you have suction gun use it to empty p/s pump resivour.
Get 5 quarts of specd hydraulic oil and top off tank.
Need helper to keep pouring in fluid while you are in a RUNNING truck with wheels off ground and at a reasonable speed turning lock to lock. You will absolutely also need to press on brake pedal firmly intermittently to keep oil passing though the system into bucket.
That’s it I would use ALL 5 QUARTS for a flush to be proud of.
Last thing I put a filter on my return line forget name but it’s a magnetic filter that grabs any fine metal. Not restricted by mesh so it’s the one.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3” CAC Pipes & CSF 7106 I.C.
4” Diamond Eye SS Exh System
W/two 4” SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
Last edited by mhatlen; 08-22-2019 at 03:24 PM. Reason: Still can’t spell. Or do much of anything else 1/2 time
mhatlen is offline
post #4 of 17 Unread 08-22-2019, 03:26 PM Thread Starter
Quoted: 11 Post(s)
I ran the entire system way to low and the steering seemed to be sticking...So I flushed a gallon of Merc LV tranny fluid through the reservoir and out into a bucket and that seemed to fix the problem for a few days, but now its back to acting up so Im hoping its just air in the line.
Is Merc LV the correct fluid?
My truck has a filter of some kind on the line, I was going to take it off and flush it out to make sure it was flowing.
post #5 of 17 Unread 08-22-2019, 03:39 PM
mhatlen's Avatar
Garage
Mercon V is what is recommended. But they quit one of their hydraulic oils.
Hang on
CAT EC-1 coolant
mhatlen is offline
post #6 of 17 Unread 08-22-2019, 03:45 PM
mhatlen's Avatar
Garage
It’s out there Valvoline also has it.
I’m not one to ask if the LV is a proper option.
I just don’t see LV listed
CAT EC-1 coolant
mhatlen is offline
post #7 of 17 Unread 08-22-2019, 04:11 PM Thread Starter
Quoted: 11 Post(s)
Thanks man. I was told it was updated to the LV, but I dont know for sure
post #8 of 17 Unread 08-22-2019, 04:16 PM
Quoted: 337 Post(s)
Garage
Wouldn't regular hydraulic oil work? Like Hy-Tran or Torque Guard -- or does it need to be synthetic?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #9 of 17 Unread 08-22-2019, 04:56 PM
Quoted: 7 Post(s)
Garage
mhatlen is correct, I neglected to mention the flush procedure.
post #10 of 17 Unread 08-22-2019, 05:37 PM
Quoted: 337 Post(s)
Garage
Interesting information
This is for Mercon V oil
Do not use in applications where MERCON® ULV, MERCON® SP, MERCON® LV, MERCON® ULV, Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended
This is for Mercon LV
Do not use in applications where MERCON® ULV, MERCON® V, MERCON® SP (exceptTorqShift®), Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended, or in power take-off units
This is for Valvoline
Valvoline ATF for MERCON V Applications
see the pic below
Name:	bandicam 2019-08-22 21-35-44-473.jpg
General note:
Hydro is offline
