Bleeding the hydroboost system? - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 17 Old 08-23-2019, 06:19 AM Thread Starter
Quoted: 11 Post(s)
Originally Posted by mhatlen View Post
No that is NOT how its accomplished
Im giving another two bits here.
Pull return hose off the hydro boost and get 6 of 3/8 line. Connect it to boost and drop it ina 5 gal bucket.
Hope you have suction gun use it to empty p/s pump resivour.
Get 5 quarts of specd hydraulic oil and top off tank.
Need helper to keep pouring in fluid while you are in a RUNNING truck with wheels off ground and at a reasonable speed turning lock to lock. You will absolutely also need to press on brake pedal firmly intermittently to keep oil passing though the system into bucket.
Thats it I would use ALL 5 QUARTS for a flush to be proud of.
Last thing I put a filter on my return line forget name but its a magnetic filter that grabs any fine metal. Not restricted by mesh so its the one.
When you take one line off and put the other back on doesnt that add air into the lines?
crankn101 is offline
post #12 of 17 Old 08-23-2019, 06:28 AM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
No for the best answer. It’s the highest point of the system and why it’s in the location.
Other factor is that’s a return line so any air that would still be up in the area isn’t for long since it’s one directional flow it will send it to the tank that’s vented at the cap.
I do feel the wrong oil is in it.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #13 of 17 Old 08-23-2019, 06:30 AM
mhatlen's Avatar
Garage
Im gonna double check on the LV
Hopefully its not a naked girl.
CAT EC-1 coolant
mhatlen is offline
post #14 of 17 Old 08-23-2019, 06:36 AM
mhatlen's Avatar
Garage
It’s No Bueno my friend.
It’s LV low viscosity fluid not to be used with Mercon V
Go get at least 4 qts of Mercon V or a exact spec from Valvoline or anyone else
Then follow as I stated above. Then let us know it’s back to behaving again
CAT EC-1 coolant
mhatlen is offline
post #15 of 17 Old 08-23-2019, 06:46 AM
mhatlen's Avatar
Garage
Don’t beat yourself up on that LV being sold to you with a yes sir thats the new replacement.
It happens and I have had happen to myself.
I truly don’t think it’s caused damage it’s just not what the pump likes for building hydraulic pressures.
Chalk it up as a day things went haywire by some dummy who set it in motion.
Not a big deal. Good luck on it. It will be fine.
CAT EC-1 coolant
mhatlen is offline
post #16 of 17 Old 08-23-2019, 06:53 AM Thread Starter
Quoted: 11 Post(s)
Ill clean my little filter out then re-flush with the Merc V
mhatlen likes this.
post #17 of 17 Old 09-18-2019, 05:44 AM
mhatlen's Avatar
Garage
Would have been nice to know if it’s back to normal. Maybe no news is good news.
Dunt kno.
CAT EC-1 coolant
mhatlen is offline
