Who has done the hutch mod? - Page 2 - Ford Powerstroke Diesel Forum
 7Likes
post #11 of 13 Old 08-23-2019, 11:34 AM
Quoted: 159 Post(s)
Originally Posted by ZMANN View Post
the rash of Ford Ambulance fires were all gasoline if I recall correctly ? metal tanks ? But preventing joe user from overfilling his tank and not being able to put fuel into and above the pick up/ sender fitting and hose clamps is not a bad idea IMO
and leaving room for fuel expansion is not bad either
I did the harpoon and get over 50 gallons now
(I harpooned my Titan tank ;-)
Yep, that’s what promoted the design criteria, videos of ambulances burning. Ford ended up buying a whole lot of vans back, too. Entire fleets in some cases.
It carried over to the diesels, possibly due to an over compensation, but you have to also put into context that the diesel tanks have a vent on the top of them, not sealed like the gas tanks. We haven’t seen a big issue of diesel spills, but there are a lot of things done under caution. There is a one way vent valve, a small plastic one.
I’ve Harpooned two of my trucks.
Jack
Former Vehicle Test Manager, Friction Products.
03 F350SC 4x4 6.0 Auto 5/30/03
YouTube Videos - TooManyToys
Never buy a Ford Remanufactured motor
TooManyToys is online now
post #12 of 13 Old 08-23-2019, 01:24 PM
Quoted: 515 Post(s)
Harpooning is one of the best mods you can do IMO.
mhatlen likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #13 of 13 Old 08-23-2019, 05:05 PM
ZMANN's Avatar
Quoted: 4034 Post(s)
Originally Posted by TooManyToys View Post
Yep, thatís what promoted the design criteria, videos of ambulances burning. Ford ended up buying a whole lot of vans back, too. Entire fleets in some cases.
It carried over to the diesels, possibly due to an over compensation, but you have to also put into context that the diesel tanks have a vent on the top of them, not sealed like the gas tanks. We havenít seen a big issue of diesel spills, but there are a lot of things done under caution. There is a one way vent valve, a small plastic one.
Iíve Harpooned two of my trucks.
I actually use more than one vent valve on mine and i use a two way vent / intake fitting
psi releif if it hits a certain pressure but let's air in anytime mounted super high in the bed just Incas i over fill I want the filler to be the low point not the vent fitting
it was all in an attempt to get full flow fueling without auto shutting off the pump at the big rig station lol
6.0 flush pdf
ZMANN is offline
