6.0 MPG with lift and 37’s? - Page 2 - Ford Powerstroke Diesel Forum
 17Likes
post #11 of 25 Old 08-22-2019, 03:32 PM Thread Starter
Ryan05KR's Avatar
Quoted: 5 Post(s)
Ok cool, price you pay when you have 37’s and 22’s I guess. Luckily diesel is almost same price as gas in Texas now. Anyone run Archoil products?
Ryan05KR is offline
post #12 of 25 Old 08-22-2019, 04:03 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1683 Post(s)
Garage
I will throw in my two bits.
First thing first if you have a engine with issues especially head gaskets leaking mileage suffers. That becomes worse exponentially with other issues on top of another.
I got 11 mpg from Los Angeles to Elk Grove with puffin heads and no tune.
Had engine gone throw added intercooler exhaust turbo fuel pump ECM FICM tuners and other mods to improve the engine performance. Miles per gallon went to 17-18mpg Highway. I do have a gearing advantage with 38” tires the engine lumbers along on the highway at 70mph. Forget rpm @ 70 mph but it’s a lot slower.
If my engine was stock tires would have dropped fuel mileage but I probably added about 150HP and efficiency is way up.
All around mpg is around 14mpg. I’d bet 7-10 puttin around town depending on speed traffic.
Most I ever saw was 21 mpg but I did it going up to mountains and best part of it was back down with gravity Free Bee. EGR delete won’t do anything for mileage.
A SCT Tuner w/ PHP custom tunes helped a lot. I have the Hypertech gizmo and speedo is spot on. I’ve calculated by hand a few times and at worst 1-2 mpg different then the Stork that adds it all up for panel display.
Bottom line if mpg is high on your list: get a Prius.
Qholic likes this.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #13 of 25 Old 08-22-2019, 05:06 PM
Sock Puppet's Avatar
Quoted: 575 Post(s)
What kinda mileage does a Prius get with 37's?
Qholic, mhatlen and SparkyF250 like this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #14 of 25 Old 08-23-2019, 05:30 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
Originally Posted by Ryan05KR View Post
Bought the truck with all the upgrades. 22-14 would not have been my choice but looks awesome. I drive a lot of highway miles and was just wondering if I could make some improvements. Archoil fuel additive work?
You do realize you are going to continue catching a hard time.
A fuel additive for MPGs when you are pushing custom wheels and oversized mud tires down the highway, sure, yea do that.
Make sure you swap out the air in your tires for nitrogen too, that will help.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #15 of 25 Old 08-23-2019, 09:36 AM Thread Starter
Ryan05KR's Avatar
Quoted: 5 Post(s)
I was just seeing what others are getting out there
Ryan05KR is offline
post #16 of 25 Old 08-23-2019, 09:55 AM
Heavy_GD's Avatar
Garage
Yes, you asked a question that has been debated in many threads, and some have posted actual results and improvements.
That said, maybe this is your first time on a forum so I will say that if you cant take a joke the internet may not be for you.
Also, as part of our rules, dont bypass the profanity filters just to antagonize.
JustinOOO9 likes this.
GD
Heavy_GD is offline
post #17 of 25 Old 08-23-2019, 01:56 PM
Spirit's Avatar
Quoted: 23 Post(s)
Originally Posted by twood71 View Post
I get, crap I done forgot what I get?
well I know I get better at 60mph vs going 70mpg in my 6.0
I just did a trip in my 6.7 Monday to Nashville Tennessee to see Iron Maiden, got 18.2 there and back was 18.5. must been the wind in my back lol
Side note for Down Town Bridge arena Nashville Tennessee, not set up for SuperDutys'
Iron Maiden? In Nashville?? That's pretty remarkable...
mhatlen likes this.
Spirit is offline
post #18 of 25 Old 08-26-2019, 05:40 PM
My best on 35's is 18, usually around 13-15 in city during summer and 9-11 during winter (warming up). And also depends on how you push the throttle. I run a edge tune in mine last 6 years. Otherwise truck is mostly stock with 4 inch exhaust.
Bornsilly9 is offline
post #19 of 25 Old 08-28-2019, 04:30 PM
Atomic's Avatar
Quoted: 4 Post(s)
I have tunes from Quick Tunes, home of the loony tune, with 4" lift and 35/12.5/18's and I average 15 mpg. I'm no granny but I'm no teen either. I get on it here and there, do 70-80 on highway and a fair amt of city. Don't listen to the guys saying they get 17+ in a 6.0. They also have ocean front property in Nevada they'll sell you cheap
Atomic is offline
post #20 of 25 Old 08-28-2019, 04:54 PM
SparkyF250's Avatar
Quoted: 3350 Post(s)
Garage
To kinda answer the additive question, use it for lubricity, water demulsification and cetane boost. I use Stanadyne, HSS Everday Diesel or OptiLube for the above reasons. These trucks are known for a lot of things, good MPG's ain't one of them. That said, I put a 4oz sample bottle of the HSS Everyday on the way home from UCC this spring and I got slightly better MPG than usual, was it the additive or straight shot on the interstate? I dunno
mhatlen likes this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
