zf6 clutch options - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-20-2019, 05:21 PM Thread Starter
reebadoo's Avatar
Quoted: 4 Post(s)
zf6 clutch options
i believe my clutch is slipping a little. and i was wondering if anyone has done a write up on changing the clutch? and does anyone else know about clutch options? any input? thanks for the help!
2004 f350 6.0, zf6, egr delete, aftermarket exhaust. and a bullydog 40420. Over 200,000 miles!
1977 ford f250 ranger xlt 400 with a c6 4x4- time for some fun!
reebadoo is offline
post #2 of 7 Old 08-20-2019, 06:28 PM
Sock Puppet's Avatar
Quoted: 581 Post(s)
@[email protected] can help you out with some options.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #3 of 7 Old 08-21-2019, 03:53 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
I run a South Bend double disc in my 2006. After adding power over time, the stock clutch would start slipping when I got over 2/3 throttle, so I upgraded it. Been very happy.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #4 of 7 Old 08-25-2019, 03:55 PM Thread Starter
reebadoo's Avatar
Quoted: 4 Post(s)
ive been abusing my clutch. as far as i know its a stock clutch with 230k, but pulling more than 15000k through mud snow and doesn't grab the way it use to. i believe its slipping and im just looking for something i can slowly add more power to and not have to worry.
reebadoo is offline
post #5 of 7 Old 08-25-2019, 06:17 PM
00t444e's Avatar
Quoted: 623 Post(s)
I have South Bend's highest rated single disc, and it has worked good for 3 years, engagement is smooth and it doesn't slip under full power. However next time I will go with the dual disc because I want something that will grab better when I try to launch it. The single disc doesn't like high rpm launches in 4x4.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #6 of 7 Old 08-26-2019, 05:24 AM
Quoted: 1470 Post(s)
Feedback Score: 4 reviews
This is the one I would recommend.
https://cncfab.us/i-30497997-south-b...dd3250-60.html
Mainly because its so easy to make good power with a 6.0L and just a tuner can get you very close in HP to the highest rated single disk they have.
post #7 of 7 Old 08-26-2019, 05:43 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
That is the clutch I have, and am very happy with it. Just beware that the dual disc clutch is different than a single disc in a few ways. The pedal is stiffer than stock, it can be "grabby" when starting off in 1st or reverse but you get used to how it behaves and the clutch isn't fully released until the pedal is completely depressed (to the floor). I mention this because if the clutch isn't fully released, it can be difficult to shift into first or reverse. Again, you get used to how it behaves, and I don't even notice it anymore.
Chris is offline
