Your Experience with Exhaust Manifold Bolts? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-17-2019, 08:36 AM Thread Starter
frozenpepper70's Avatar
Quoted: 7 Post(s)
Garage
I am replacing the passenger side exhaust manifold on my '03. Do any of you have recommendations or tips? Currently, I am soaking the bolts in penetrating oil every night until I begin the job this upcoming week. I plan on removing the fender well too.
Thank you.
frozenpepper70 is offline
post #2 of 10 Old 08-17-2019, 10:09 AM
7.3lf550's Avatar
Quoted: 68 Post(s)
Best tip i can give you is DONT BREAK ONE OFF
i know....it just happens sometimes.
Some swear that pulling them cold is the best. Some say hot is the best.
Ive always pulled fenderwell and started breaking them loose. if i get a stubborn one i start the truck and let it run for a minute and see if i can get it. I repeat until it comes out.
I have had all bolts come out without an issue on a truck with 220k on stock manifolds.
I have had 3 break off on a truck with 90k miles.
Heat can definitely be your friend though. And the very best way to heat is to run the truck as it heats the head.
7.3lf550 is offline
The Following User Says Thank You to 7.3lf550 For This Useful Post:
frozenpepper70 (08-17-2019)
post #3 of 10 Old 08-17-2019, 01:03 PM
ChrisSki's Avatar
Quoted: 550 Post(s)
Once you get them out, replace them in case you need to get in again. Stripping the Allen head and partial stripping the Allen head is what got me. I changed the drive’s side, but brought it to the shop for the passenger side. My hands couldn’t fit in to get most of the bolts loose. I quit before I got myself to a point where I had to tow it. I have also had luck breaking bolts loose with some CRC cold spray. Spray for about 30 seconds, and then loosen.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
The Following User Says Thank You to ChrisSki For This Useful Post:
post #4 of 10 Old 08-17-2019, 01:26 PM
Quoted: 43 Post(s)
When I did my heads, I took mine off out of the truck once the head was removed but they all came out pretty easy. When I put the manifolds back on it was with the heads on the engine and it wasn't fun.. I had my fender skirt off so it made it a bit easier. If you are only doing one side might be worth pulling the inner fender out as it's not too hard to get out.
DAV!D is offline
The Following User Says Thank You to DAV!D For This Useful Post:
post #5 of 10 Old 08-17-2019, 07:30 PM
repalmer's Avatar
Quoted: 558 Post(s)
You're not really doing anything with the penetrating oil.
I used my Ridgid impact driver on the driver's side, zipped them right off. But my truck is from Cali desert so no rust. Don't know your situation.
You could try them with a ratchet, and if they don't want to loosen just cut the head off. That way you can get to the threads with penetrating oil. If you break one with ratchet, it'll most likely break right at the head surface then that involves drilling and possibly head removal if you can't get a drill to it.
If you cut it off, then you can use a torch to heat it up and a spray bottle with water to quench it. That usually shocks the rust enough to allow it to come out
repalmer is offline
post #6 of 10 Old 08-17-2019, 10:26 PM
BTL
BTL's Avatar
Quoted: 194 Post(s)
When my mechanic removed my exhaust manifolds he told me he did not have a problem removing any of the bolts. As a matter of fact I had to go to my local Ford dealer and buy three new bolts with the spacers because he found three of them were missing.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4” SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8” draw tube
BTL is offline
post #7 of 10 Old 08-18-2019, 06:31 AM
Fummins Mod
junior125's Avatar
Quoted: 2190 Post(s)
Garage
spray em a few days before hand with some pb blaster if you have the opportunity to do so
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #8 of 10 Old 08-18-2019, 12:52 PM Thread Starter
Quoted: 7 Post(s)
Garage
Wow thanks for the good info, appreciate that.
Sent from my Pixel using Tapatalk
post #9 of 10 Old 08-21-2019, 07:19 AM
Brrrrrrr......cccccold
Quoted: 395 Post(s)
When you replace the manifold bolts, check with ARP, I believe they have the titanium set for something like $30.
Are you replacing the manifolds?
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #10 of 10 Old 08-21-2019, 07:22 AM
Quoted: 395 Post(s)
In the past, when we did manifold bolts in my shops we would heat them with a torch. The best lubricant out there to break them babies free will be Kroil.
It's $20 a can but it will loosen them. Soak overnight. Spray multiple times a day too.
Zach
168,084 miles....
zsargent is offline
