Loud bang air hissing now no boost - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 13 Old Yesterday, 05:48 PM Thread Starter
Quoted: 6 Post(s)
So I drove over the Cascade mountain range to pick up a trailer. The trailer weighs maybe 4000 lbs. I starting to get on the highway wide open throttle got to about 50 miles a hour and there was a loud bang and then heard a few seconds of hissing as the boost dropped to zero. Pull over checked all the boots and they were still attached. Limped back to where I bought the trailer and parked it back where it was. With no boost drove back home 125 miles. Going up a few grades with no boost meant falling below 40 mph dam what a dog it is without the turbo boost. So where do I start? I can still hear some hissing while driving but not parking with the hood up.
Dauntless1971 is offline
post #2 of 13 Old Yesterday, 06:07 PM
SparkyF250's Avatar
Quoted: 3133 Post(s)
Garage
If you have an 05 you probably have the black plastic cold air tube from the intercooler to the intake. If so I'd bet it's cracked. Hope you were monitoring your EGT's while driving without boost. Bet it got real hot
Dauntless1971 and john galt like this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is offline
post #3 of 13 Old Yesterday, 06:09 PM
Quoted: 308 Post(s)
Garage
The plastic tube on the drivers side like to split at the bellows(pull the air filter box out to inspect), also look at the air cooler tank on the passenger side -- can spit the gasket out where the tank seals to the radiator
You build little to no boost without load on the engine, so your not gonna see anything(leaks) at idle
Use a 4 inch rubber plumbing cap and air fitting on the turbo intake to pressurize the intake system -- start about 10 psi and go up if you feel your "plumbing" job is secure -- stop around 30psi, no need to create any problems
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #4 of 13 Old Yesterday, 06:32 PM Thread Starter
Quoted: 6 Post(s)
Yes I grabbed a ladder and with a better view the intake tube is cracked. Thank you gentlemen. Now where do I find something of better quality. perhaps this ford part 6C3Z-6C640-AA
post #5 of 13 Old Yesterday, 06:36 PM
Quoted: 308 Post(s)
Garage
Well, it has ran a lot of miles with the current style pipe, prolly will run similar with a new one -- or change over to the older style metal tube, some of the Vendor sponsors on this site sell the metal one
General note:
Hydro is offline
post #6 of 13 Old Yesterday, 06:48 PM Thread Starter
Quoted: 6 Post(s)
Ok I hate being naive but where would I find vendors on this site?
post #7 of 13 Old Yesterday, 07:15 PM Thread Starter
Quoted: 6 Post(s)
As much as I would like to help any sponsors here, it appears Amazon can get me the stock upgraded part the fastest. Oh well I think it sucks, but actually it appears it blows. Well the stock part it is.
post #8 of 13 Old Yesterday, 07:25 PM
jokester00's Avatar
Quoted: 412 Post(s)
Garage
If you don't need your truck for a few days, I still have the plastic stock one at home off my '05 I'll sell ya cheaper than Amazon...
Where are you located?
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #9 of 13 Old Yesterday, 07:31 PM Thread Starter
Quoted: 6 Post(s)
-jokester
No Thank you though, I think I got it figured out not able to help any sponsors here but Lasco Ford appears able to get me the upgraded one either 8-20 to 8-22 for just 95 dollars.
Really had a bad day on the highways today. And now the trailer I just spend good money on is 2 and half hours away.
post #10 of 13 Old Yesterday, 07:34 PM
jokester00's Avatar
Quoted: 412 Post(s)
Garage
Where you located? I might be able to help you out with the trailer dilemma.
-jokester
Edge EAS EGT probe
Blue Spring Upgrade
