engine coolant overheat 2007 F250 6.0 - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 18 Old 08-11-2019, 07:53 AM Thread Starter
Motchman's Avatar
Hi everyone, I was pulling my boat Friday when i got an engine coolant overheat alarm, it was up to 235 when i saw it, i was in traffic and did not notice it going up until the alarm, I shut it down let it cool off, after that I turned it around and started home, turned off the AC and drove it home, as I was driving back the engine coolant ran about 208 average, in traffic it got up to 216. The EOT stayed with in 10 degrees of the ECT.
Next day put a new Thermostat in it, and it's running 204 EOT and 202 engine oil temp. Normal it runs 198 ECT.
Could it be Water pump or Clutch Fan needs to be replaced? Never have replaced either one, I had a new oil cooler put on last year. Was just wondering which direction to go, I was thinking of replacing both, but the Fan clutch is pretty expensive. Any suggestions?
Motchman is offline
post #2 of 18 Old 08-11-2019, 09:02 AM
ZMANN's Avatar
Quoted: 3864 Post(s)
how many miles ?
i consider replacing the water pump and clutch as part of preventative maintenance if you are anywhere near 150k i did mine much sooner just because I am far from home often and a tow $$ would suck
check you coolant condition or replace it latley ?
6.0 flush pdf
ZMANN is offline
post #3 of 18 Old 08-11-2019, 09:09 AM
ChrisSki's Avatar
Quoted: 540 Post(s)
I personally think 204 for an ECT is not bad, provided this is in a very hot area like AZ. The thermostat is probably a 204 thermostat. If you are running that, I don't think there's a reason to add the clutch or water pump. The OEM thermostat fails in the open position, but a prior owner could have added a non-OEM thermostat and with the temps you see, I think you fixed it.
If you do decide on replacing one, I'd consider both, since you remove the clutch to get the water pump and it's only three more bolts to get to the water pump. Most of the work is getting the clutch off. With parts in hand, that took me 4 hours start to finish, and I'm rather slow, so I think a shop would do both the water pump and clutch much quicker.
My assumption with this is you did not need to fill the coolant. If you did, I'd start thinking something different like EGR or Heads, or a much easier to fix coolant leak.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 18 Old 08-11-2019, 12:40 PM Thread Starter
Motchman's Avatar
zmann, I have 168,000 miles, and changed the coolant last year along with the oil cooler, and have never replace the clutch fan or water pump, today its running fine, but i did some more damage to the radiator plug, i checked for leaks and it was loose, and i just over tightened it, and plastic did not handle the extra turn, so now i need to drill it out and replace the plug!!
ChrisSki, that was my plan go ahead and change both and the belt also, it's hot as hell here in Kentucky, i have noticed that my air condition also is not blowing as cold when just at an idle, not sure if that is a coincidence or what?
Motchman is offline
post #5 of 18 Old 08-11-2019, 01:15 PM
ChrisSki's Avatar
Quoted: 540 Post(s)
The 7.3 clutch definitly spins more at idle. Don't know if the fact that i installed or not, but my A/C seems better especially at idle with the 7.3 clutch compared to the 6.0 clutch . IMO that's the 7.3 clutch moving extra air moving over the condenser. I think a bad 6.0 clutch would make the AC warmer.
Ravelco
Good 6.0 Reading:
ChrisSki is offline
post #6 of 18 Old 08-12-2019, 10:42 AM Thread Starter
Motchman's Avatar
Thanks guys for all the information, I’m off work and headed over to NAPA to get the parts and see if this helps, I’m sure it will!!!
Motchman is offline
post #7 of 18 Old 08-14-2019, 02:54 AM Thread Starter
Motchman's Avatar
Well I found out it was the wire going to clutch fan had gotten severed by the fan blade, looks like the plastic bridge that supports it had broke in the middle and allowed it to drop down in the pathway of the fan, and there you have it😂.
ID:	721765   Click image for larger version
Motchman is offline
post #8 of 18 Old 08-14-2019, 10:27 AM
BTL
BTL's Avatar
Quoted: 192 Post(s)
BPD makes a wire shield to prevent that from happening again.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4 SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8 draw tube
BTL is offline
post #9 of 18 Old 08-14-2019, 10:35 AM Thread Starter
Motchman's Avatar
BTL? I’ve looked it up but no results
Motchman is offline
post #10 of 18 Old 08-14-2019, 01:31 PM Thread Starter
Motchman's Avatar
you were right, it’s the clutch fan not working that has the AC blowing warmer at an idle.
Motchman is offline
