fuel supply/turbo upgrades - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-06-2019, 01:29 PM Thread Starter
Kingranch252's Avatar
Garage
looking to get some power out of my truck. I will tow will it so keep that in mind. not looking to drag race. right now fuel is stock, have a gt4088r turbo which i believe is 62.5mm. running innovative tunes, was thinking 175cc injectors but as far as a turbo and fuel pump im lost. any help is appreciated.
Kingranch252 is offline
post #2 of 6 Old 08-06-2019, 03:06 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 874 Post(s)
Feedback Score: 3 reviews
You say the turbo is a GT4088r but you want a bigger turbo?? Is the turbo stock or did you buy the truck already upgraded??
Pending your response; For a towing setup: A nice KC SG 1 maybe 2, with 155cc sticks, Airdog or other lift pump, maybe a fuel system. Of course the tuning might need to be tweaked for best results. Added "upgrades": Maybe a intake manifold, turbo back straight pipe, bellowed Y-pipes, maybe a inter-cooler.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 6 Old 08-06-2019, 05:57 PM
joe blow's Avatar
Quoted: 141 Post(s)
Pretty much a perfect combo if you ask me (you about named all I've got)
I originally was towing with stock injectors and a stage II, utilizing Matt's tunes. The truck ran great but once I yanked the motor out for heads/studs I decided "let me spend more money I don't have LOL".
I added 175/30's, an ODAWG stage II and an airdogII and all the other goodies that it got when it was on a stand.
The tuning was tricky because gearhead had to change them to a full fuel tune and the damn truck was powerful and the egt's were uncontrollable. Gearhead tweaked the tunes here and there (both race and tow) and it runs flawless now.
While towing a pretty heavy weekend warrior, I am lucky to see 1300* sustained up a good size hill at around 2800-3200 rpm. Keep in mind I am straight piped and ridding the truck of the restrictive oven/catalytic converter helped a bunch
The ADII wiring harness IS A JOKE! If you plan on buying one, plan on redoing it with 8-10AWG (long positive and negative) as I found out the hard way and melted wires.
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is online now
post #4 of 6 Old 08-07-2019, 04:37 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
I am running a KC stage 1, Spearco intercooler, Airdog along with some other modifications. No matter what you do, getting a good tune is one of, if not the most important things you can do. I've seen people throw thousands and thousands of dollars at a project, but scrimp on a few hundred bucks for a custom tune. Never understood that.
With my current setup, which is pretty much what has been mentioned previously minus the injectors, I couldn't be happier driving street or towing.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #5 of 6 Old 08-07-2019, 05:18 AM Thread Starter
Garage
let me be more specific the turbo is a turbo lab rebuild kit. includes new compressor housing and billet wheel 63.5mm. i bought the truck completely stock. but i want to go ahead and replace my injectors. i will be towing a 18 foot trailer with a zero turn lawn mower. i do have a heavy duty trailer for towing heavy equipment and or trucks but i rarely ever use it. i do not tow with it a lot. once or twice a month but i want it to be able to tow anything i hook to it. was curious about a 6.7 fuel pump. i happen to have one on stand by but is it worth the money to go ahead and buy a airdog or something similar.
post #6 of 6 Old 08-07-2019, 06:57 AM
joe blow's Avatar
Quoted: 141 Post(s)
It all depends on what you want. Some people talk about how the ADII has dependability issues, which I have seen first hand regarding the weak wiring harness. Others say that having a stock 6.7 pump will feed your system plenty well plus you have the available pump at any dealer if it goes bad. I have seen the rigors and parts sourcing of installing a 6.7 pump and it really seems like a huge PITA to do and expensive.
Both will serve you well and I can attest to the ADII having done so for me.
If I had to do it all over again, I would still do the ADII because I like the filtration and the preparator features it offers for the fuel delivery.
My opinion
Joe
Joe
